Author Topic: I have a black shadow in my monitor screen can i get rid of it?  (Read 4462 times)
berlincam86
  • Last login:January 30, 2020, 10:03:28 am
  • I can't wait to build my first cabinet!
« on: December 11, 2007, 07:28:31 pm »
I have a megatouch super 4 bartop arcade game and I have this black shadow in the upper right corner. Will i be able to get rid of it? And how? There are a few new caps on the chassis but not all of them.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: I have a black shadow in my monitor screen can i get rid of it?
« Reply #1 on: December 11, 2007, 10:34:27 pm »
if the individual convergence/purity rings have NOT been moved , the ring assembly may need to be repositioned.
however, i think the convergence has been altered, as it does indeed appear to be misadjusted........
first step is to deguass the crt .
to align , begin with a mirror and a crosshatch or dot pattern on screen.
note :  >>> DO NOT TOUCH THE RED WIRE ON THE PICTURE TUBE<<<    20-30KV PRESENT !!!!!!!!
adjust the rings to bring red,blue and green lines into alignment observing the reflection ( mirror)
the original ring position may be factory marked- (making realignment easy- line up the marks)
the same can be done to return the rings to a starting position for practice (or if in doubt)
qrz
shilmover
  • Last login:September 25, 2018, 12:36:59 am
« Reply #2 on: December 11, 2007, 10:45:41 pm »
qrz,
That reminds me of a question that i have been meaning to ask but keep forgetting...  Can you touch the rings while the monitor is on?  Have not had to do it, but just in case I ever do.
My projects...
Finished:  Stargate (only 'cause I got it that way)
In progress:  Tron, 48-in-1 for School Auction, DKJr (currently a 60-in-1), Millipede, MAME System
qrz
« Reply #3 on: December 11, 2007, 10:55:11 pm »
yes, and that is the way to make the adjustment.
the set must be operating .
a good rule of thumb for working around high voltages is to do so with one hand behind your back.
and BE CAREFUL.   > don't fear electricity , but you must respect it !!<
qrz
berlincam86
« Reply #4 on: December 12, 2007, 06:59:38 am »
Ok ill give that a try after work. Ill get back to you if it doesnt work. Thanks.
berlincam86
« Reply #5 on: December 12, 2007, 12:44:12 pm »
ok i tried that and nothing happens. Any other suggestions?
« Reply #6 on: December 12, 2007, 12:47:49 pm »
Try a good degaussing.
berlincam86
« Reply #7 on: December 12, 2007, 12:50:01 pm »
Did that too. There is a switch on the little remote circuit board and i have used it a couple of times and it does nothing.
« Reply #8 on: December 12, 2007, 12:51:03 pm »
It does nothing or it doesn't solve your problem?  If it does nothing, it's not functioning.
berlincam86
« Reply #9 on: December 12, 2007, 12:52:37 pm »
Oh, yes, it does the degaussing but doesnt do anything to the shadow.
grantspain
« Reply #10 on: December 12, 2007, 01:22:38 pm »
do you get the same with a blank raster(no signal connected),if so could be a damaged tube
berlincam86
« Reply #11 on: December 12, 2007, 01:27:14 pm »
when i pull the rgb and sync wire harness the screen goes to a green color and yes the shadow is still there.
berlincam86
« Reply #12 on: December 12, 2007, 01:45:22 pm »
On some screens i dont see it but if its a purple screen or green i can see it good. It doesnt seem to show with a red or blue screen. Or of course i cant see it with a black screen.
grantspain
« Reply #13 on: December 12, 2007, 05:46:46 pm »
so if you disconnect the green video input you don't get this shadow?
qrz
« Reply #14 on: December 12, 2007, 09:10:42 pm »
berlincam86, a pm is en route.
it should help a bit
qrz
berlincam86
« Reply #15 on: December 12, 2007, 09:30:31 pm »
Yes i got it i will work on it as soon as i can and ill let you know what happens. Thanks alot for the help.
berlincam86
« Reply #16 on: December 15, 2007, 10:33:36 pm »
Just to let anyone know who cares. The problem was solved. the shadow happen to be something with the deflection yoke itself. I happen to move it while i was screwing around with the convergance and it went away. the wedges are not in there very well but they are glued so i put a piece of paper in there to keep the deflection yoke still(I hope this is ok to do). I still have purity and convergance problems but i dont have a pattern generator to do that. I have it kind of close but its still not right. Maybe ill take it to a tv repair man to have that done. Thanks guys for all your help.
qrz
« Reply #17 on: December 18, 2007, 10:09:18 pm »
all u need is a stationary pic . try one of the service screens.
if u have the yoke correctly positioned, insert the rubber wedges and seal in place with a bead of silcone rubber.
once dry , then tackle the convergence . suggest marking a line accross the rings for a reference .  why ?
just line up the mark to return to the starting position.  ;)
aligning convergence is not hard with practice .
qrz
berlincam86
« Reply #18 on: December 27, 2007, 11:05:33 pm »
qrz i got another problem with another monitor can you help me?
