Author Topic: Best Playstation Emulator(s)?  (Read 1721 times)
Red
  • Last login:November 07, 2017, 08:37:51 am
« on: December 11, 2007, 01:21:18 am »
What are the best Playstation Emulator(s) currently still in development that offer the best game compatibility?  Thanks.
Red
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
Re: Best Playstation Emulator(s)?
« Reply #1 on: December 11, 2007, 03:26:28 am »
Theres EPSXE which in my opinion is overly bulky buggy and poo and pSX 1.3 which is the nuts for running in a cab. It also requires no plugins to use just grab your bios and iso image and of you go. Compatibility for both is great although tekken 2 is broken in the latest pSX.
When pixelated clipart just wont do, just call for Betty
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #2 on: December 11, 2007, 04:52:04 pm »
I have been extremely satisified with PSX, great emulator and plays at least 90% of everything perfectly.  Very easy to set up and the only option for a cab IMHO.
My Websites
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #3 on: December 11, 2007, 08:18:19 pm »
Although ePSXe is rather finicky, I've found I get the best performance from it and I'm rather stuck to it.   I tried using pSX (again recently since 1.13 came out), and I was disappointed with the limited graphics options and the speed that I personally acheived...
Personally, I use ePSXe along with ePSXeCutor so I can set the best settings for each game I have set up (Bilinear filtering for 3d games so they look crisp, with none for 2d games so the sprites don't look blurred...) After I set up the first few games, adding new games was just a matter of copying the profile of a game that was similar  and changing the rom (copying Tekken 3's settings for Street Fighter EX)
So in MaLa I have epsxecutor set as the emulator with the game config name as the "rom" name which loads everything perfectly..
I will admit that epsxe is a bit of a hassle (especially when it comes to trying different plugin combos to get specific games to work right), but it's been worth it in my eyes since I get the look I would want for every single game (which often makes games look like they're from a totally different system).
(WARNING though, I have found that since epsxecutor essentially closes itself and launches epsxe with the desired settings, MaLa ends up thinking that it's back into focus, which will bring everything that comes with it back into play, such as the MaLa screen saver or the background music... very annoying... I use a Windows Video screen saver instead.)
EDIT: It's also not currently in development, either....
All in all, in some cases I favor intricacy and customization over simplicity, and this happened to be one of those cases.  If simplicity and ease of setup is what you're looking for, I'd say definitely go pSX.
« Last Edit: December 11, 2007, 10:31:52 pm by Organic Jerk »
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
