Author Topic: Ikari warriors on a jamma cab with a multi jamma bd installed  (Read 2465 times)
kjoel0123
  • Last login:January 07, 2012, 09:57:19 am
  • Cabs for sale - Please see my flickr page for all
« on: December 10, 2007, 09:50:34 am »
What type of joysticks can I use if I want to play ikari warriors (the game on the multi jamma bd) on a jamma cabinet. I see that there are rotary joysticks but how do you connect them? I see that they have different connectors.
Or:  do I need to use an optical joystick like my gauntlet legacy cabinet instead?
If I can get this hooked up then that would be great !
Dedicated Cabaret cabs I currently own:
Neo Geo/ GT Complete/Mspac galaga reunion
full size cabs: Playchoice 10 Single Monitor/Nicktoons Racing/Junior King Cocktail/ Super Punchout/
Pins- Revenge From Mars/ Black Rose/ LW3
For Sale/ Trade: Digdug in Ireland Cab/83' Chexx Hockey/Battlezone/PC10 Bartop with 6 games
Check out http://www.flickr.com/kjarcade <--not updated
maxmix
  • Last login:September 27, 2016, 07:07:14 am
    • Phoneking.co.uk
Re: Ikari warriors on a jamma cab with a multi jamma bd installed
« Reply #1 on: December 10, 2007, 11:00:33 am »
I bought a couple of these.... Rare as hell tho...
One day I'll get em fitted to a cab lol and get back into Midnight Resistance and Ikari :)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=170159397901
maxmix
kjoel0123
« Reply #2 on: December 10, 2007, 06:20:47 pm »
maybe I'll just buy a rotary and snip off the end and try to wire it some how, not sure...
MaximRecoil
« Reply #3 on: December 13, 2007, 10:55:18 pm »
Ikari Warriors on a multi-JAMMA board? Well I would have no idea about that, but real Ikari Warriors boards have a pair of connectors on them which you connect the rotary switches on the joysticks to, via a 13-wire harness that comes with the joysticks. The rest of the joystick (the 4 microswitches on each joystick that provide the 8-way directional control) connect to the board via the main wiring harness, the same as any other joystick.
Ikari Warriors uses 12-position mechanical rotary joysticks (a distinct mechanical click for each position). You can use SNK LS-30's like came on dedicated Ikari Warriors machines, and there were also Wico and Data East versions that will work. Happ Controls makes a 12-position mechanical rotary joystick that will work as well.
You are not going to be able to hook up the rotary switch part of rotary joysticks to a multi-JAMMA board unless the manufacturer of the board has specifically provided the provisions for you to do so, which would be in the form of a pair of 13-pin headers on the multi-JAMMA board. So I guess you should look for something like that on your board.
Have you tried the game out yet? It's possible that they used the version of Ikari Warriors that lets you play the game with ordinary 8-way joysticks. This is a hack which aims your playable character's gun in whichever direction you push the joystick—in the manner of Capcom's Commando (1985).
« Last Edit: December 13, 2007, 10:57:55 pm by MaximRecoil »
kjoel0123
« Reply #4 on: December 16, 2007, 08:31:08 am »
I have yet to purchase the board. Makes me wonder if these rotary games on it will work with a 8 way stick..
