Author Topic: Gameplay previews "cut-off" while playing in Mamewah??? **SOLVED**  (Read 3946 times)
jacenwon
  • Last login:July 21, 2015, 04:46:17 pm
  • Professional Creative & Designer
Alrighty... so i ran into the preview bug with mamewah already, and was able to "search the forums" my way out of that mess. Now i'm stuck with this odd cutting off of the picture when the preview movies play within mamewah. anybody else have this issue?
here's a screenshot of my issue + my mame.ini & mamewah.ini text:
mame.ini
### mame.ini (mamewah v1.62) ###
emulator_title                            M.A.M.E.
### List Generation Settings ###
rom_path                                  c:\mame\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file                           c:\mame\catver.ini
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      c:\mame\mame.exe [name]{nodosbox}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       c:\mame\previews;c:\mame\titles
movie_preview_path                        c:\mame\previews
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
mamewah.ini
### mamewah.ini (mamewah v1.62) ###
### (Global) Screen-Saver Settings ###
delay                                     300
slide_duration                            3
### Audio Settings ###
enable_sounds                             1
sound_volume                              100
music_path
enable_music                              1
music_volume                              100
### Movie Settings ###
intro_movie_file
exit_movie_file
keep_movie_preview_aspect                 game_aspect
delay_before_movie_preview                1
music_movie_mix                           mute_movies
movie_volume                              75
### Misc Settings ###
emulator_root_path
auto_setup_emulators                      0
theme
wrap_list                                 0
remember_current_game                     1
keep_image_aspect                         1
refresh_images                            0
delay_before_history_dat                  2
safe_mode                                 1
show_cursor                               0
keyboard_led_states                       -,-,-
lcd_com_port                              1
lcd_settings
exit_action                               choice
maxlogsize                                100000
### External Application Settings ###
startup_app_commandlines
exit_app_commandlines
exit_and_run_app_commandlines
current_group
current_emulator                          mame
locked                                    0
the way i have the layout setup, the movie preview should use the ENTIRE black area to the right, but if you look closely, the whole lower portion of the movie isn't viewable. even on the verticle previews the movie plays dead in the center of the designated area, and the lower portion is ALWAYS cuttoff.
i did notice that when i play the movies through windows media player, outside of mamewah of course, the same thing happens - only the upper portion of the movie is visable. HOWEVER, when i use "divx player", the movie plays perfect.
any ideas as to why this is actin' foolish???
all help is greatly appreciated!
jace
« Last Edit: December 08, 2007, 07:12:30 pm by jacenwon »
• 2014 MAME cabinet build: http://tinyurl.com/jaces-mamecab-2014
• 2008 MAME Neo29 build: http://tinyurl.com/jaces-neo29-2008
jacenwon
Re: Gameplay previews "cut-off" while playing in Mamewah??? Suggestions???
« Reply #1 on: December 07, 2007, 02:11:35 am »
in hopes to help resolve this issue, here's a small video clip of it in action:
[youtube]http://www.youtube.com/v/z6k5r5cH9O4&rel=1[/youtube]
thanks in advance, folks!
jace
crummy
  • Last login:May 11, 2008, 03:01:58 am
« Reply #2 on: December 07, 2007, 03:41:22 am »
Maybe I don't understand the issue... but it seems that the video is filling as far left and right as it can. Filling up and down would stretch the video (which doesn't happen). Right?
Or is actual content being cut off?
jacenwon
« Reply #3 on: December 07, 2007, 05:05:31 am »
the video is filling left to right PERFECTLY - as far left to right as i designate when building the layout.
it's the lower content that's being cutoff on every video, no matter how large i allow the artwork area to be.
i originally thought it just may be the video files wanting to run at it's full resolution... so i made the artwork area as large as i could, and it only stretched the video to be larger, and STILL cutoff the lower portion of the video :(
This also happens with my intro/outro movie, as well as the screensaver when it involves any video. so yeah, the thing just doesn't like video for some stupid reason :(
jacenwon
« Reply #4 on: December 07, 2007, 04:08:22 pm »
a fella from another message board had suggested this:
"Could be a video format issue, although you could try changing keep_movie_preview_aspect to 'no' in the mamewah.ini"
this was my response:
i thought it may be the mamewah.ini settings at first, or perhaps just a faulty/corrupt file within mamewah. so i went and ran not only the emumovie preview clips, but random movie clips from an external drive OUTSIDE of mamewah with my 2 main movie players on the mame machine: windows media player & divx player... here's the results:
divx player played the movie files absolutely PERFECT, while windows media player cut the video off like mamewah did.
that being said, it's obvious the movie files don't like windows media player. (which i'm sure happens to be the default movie player within mamewah - terrific) is there anyway to change the default movie player within mamewah to use my divx player??? i'm pretty sure that'll solve my issue... does it sound like it?
« Last Edit: December 07, 2007, 09:38:51 pm by jacenwon »
gonzo90017
« Reply #5 on: December 07, 2007, 11:05:01 pm »
What codec are the videos using? You can use media info to find out.
jacenwon
« Reply #6 on: December 08, 2007, 12:56:07 am »
i just tried to run the videos using windows media player classic, and they worked fine. but for some reason mamewah keeps running the videos cutoff.
would the codec matter? the videos run fine in all other media players BUT windows media player 11.
i'll check out media info and let you know though, thanks!
jacenwon
« Reply #7 on: December 08, 2007, 05:45:47 am »
welp, after many MANY hours of troubleshootin' the sh*t out of my machine, i'm convinced that windows media player does not like 640x480 resolution by way of the arcadevga card.
bummer... no movie previews :(
gonzo90017
« Reply #8 on: December 08, 2007, 12:41:17 pm »
Try one of these videos and see if you still have the cut off problem. It's worth a shot.  :laugh:
gseeker.avi
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #9 on: December 08, 2007, 03:47:56 pm »
If you are using the EmuMovies Mame videos try the SQ set.  That should solve your problem.
My Websites
jacenwon
« Reply #10 on: December 08, 2007, 06:40:16 pm »
that's the only ones i used for the preview, considering there's no need for a hi-res preview.
i did some more troubleshooting last night, and found out that the video's NOT cutoff when i run a 368x240 resolution. it's tough as hell to navigate on the desktop at the res, but it plays the video fine within mamewah now :)
thanks for the suggestions folks  8)
Re: Gameplay previews "cut-off" while playing in Mamewah??? **SOLVED**
« Reply #11 on: December 10, 2007, 06:50:10 am »
Sorry I can't be much help, but I can say the following is generally true: The video's must play in Media Player correctly to play back in Mamewah.  Mamewah doesn't 'use' Media Player but it uses DirectX in basically the same way Media Player does it.
Seems to me there is something a bit funny with the video format.  Personally I use Circo's EmuMovies set and from memory have worked great at whatever resolutions I have tried.
Note: you don't need to run your desktop at 368x240 to run Mamewah at that res.  I have a desktop of 640x480 and run Mamewah at 368x240 on my cabinet.
jacenwon
« Reply #12 on: December 11, 2007, 01:08:24 am »
thanks for the reply, minwah.
yeah, it's odd that i can't run the movies from circo at 640x480.... that resolution allows me to design a bitchin' layout :( now, at 368x240, the layouts can't be too graphically advanced :(
have a good one  :)
« Reply #13 on: December 11, 2007, 04:41:08 am »
Yeah that's odd...I have just (after 3 years) got round to moving my cabinet to where I live, so I should be playing around with software a bit more soon.  I will keep an eye on the movies to see if anything similar happens...
jacenwon
« Reply #14 on: December 11, 2007, 12:45:18 pm »
yeah, i'd say it's something that should be looked at... just incase it's fixable, perhaps?
i reformated last night, and only installed the xvid codecs (as emumovies suggests). it seems all the movies run fine up until i install mamewah's "system files" - once i run setup.bat, the video is cutoff from there on out.
how can i uninstall the system files? i wanna mess with somethin' :)
thanks for the assistance, minwah  :cheers:
Circo
    • EmuMovies
« Reply #15 on: December 11, 2007, 04:43:10 pm »
I really need to pay attention to these issues and get a FAQ up one of these days, so little time.....
I test these at home, but then again my billabs monitor handles 1024x768 so it handles pretty much everything I throw at it.
My Websites
jacenwon
« Reply #16 on: December 12, 2007, 02:26:52 am »
well, the movies themselves are fine. awesome quality/clarity... i just think it's a conflict with the resolution vs. the system files within mamewah.
please check your pm's circo... i had a question in regards to your wonderful movie sets :)
« Reply #17 on: December 12, 2007, 05:38:24 am »
Sounds pretty odd.  The system files are as follows:
VB6 runtime library (required to run anything made in VB6),
MS Common Dialog (just a control for popping up open/save etc. dialog boxes),
MS Common Controls (some commonly used simple controls),
MS Comm control (used for serial port communications),
PaintX (control for displaying different image formats).
So with the exception of PaintX, these are very common things which many people have installed anyway (although they may not know it).  While PaintX is graphic related, it has nothing to do with movies or codecs, so I am sure that shouldn't be the cause of the problem.
I'm wondering if this problem could be something to do with hardware acceleration...I'll be back...
Edit: OK I assume you are using an ArcadeVGA, so have a look at this thread:
http://forum.arcadecontrols.com/index.php?topic=26313.0
« Last Edit: December 12, 2007, 05:41:19 am by Minwah »
jacenwon
« Reply #18 on: December 12, 2007, 11:13:11 pm »
i checked out the thread, and tried the hardware acceleration adjustment... no luck. the lower portion stays cutoff.
it's all good, man... i'm just going to run it at 368x240 :)
