Author Topic: Steering CP  (Read 1259 times)
AX
  • Last login:April 20, 2004, 02:07:53 pm
  • The only way to win is to cheat!
Steering CP
« on: May 11, 2003, 09:56:50 am »
I'm planning my steering CP.  for anyone that has done this I would like to see what some of your opions are.
What games you play.
what you have noticed works and doesn't work as far as shifting.
what you would change if you had to do it again.
I noticed last night with my momo that pole position plays like crap with a 270 and the shifter is high low in only one direction as ooposed to up down like the real game.
Any input is greatly appreciated and I will create a nice tutorial with pictures when I'm finished.
Thanks.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Steering CP
« Reply #1 on: May 11, 2003, 08:09:40 pm »
Pole position used a 360 degree wheel in the arcades, and 270's suck at controling these games.  Most "behind the wheel" driving games use 270 wheels, but PP & PP2 are two of the few that used 360 wheels.  These games will play better with spinners than 270s.
Here's an old-ish (0.62) table of driving games with 270 vs 360 inputs: http://urebelscum.speedhost.com/drivingInputs.html  The 270 games should play fine with you momo wheel.
Most games with hi-low gears are hacked in mame for easier keyboard play.  These game use toggle like buttons to switch from one to the other, while most original games high gear was equiv to holding down a button.  A quick hack would be to map both mame's high and low gear to both high and low gear input; if the device and the game get out of sync, pause the game, shift back into sync, and unpause the game.  The cleanest solution would be to edit the source.
Gears with more than two gears are simulated different ways, with different hacks/fixes.  If mame driver uses a "shift up"/"shift down" hack, you could map first gear as shift down, second as shift up, and driver with the gear in "neutral" when not shifting up or down.
Robin
Knowledge is Power
Smack
  • Last login:May 07, 2013, 11:40:41 pm
  • Who changed my avatar?
Re:Steering CP
« Reply #2 on: May 11, 2003, 11:02:15 pm »
I think it was Steph who helped me to tweak the polepos source to address the high/low gear issue.
If you want, I can forward you the driver file. (Just drop it in and recompile for your homebrew version.)
Just let me know. ;D
Smack
Never Let Donkey Kong Use Your Toilet.
(We're talkin' big processed brown bananas...)
Somebody out there stole my sig! LOL
