Author Topic: error 14F in the vesa call?  (Read 2229 times)
peterpiper70
  • Last login:August 07, 2021, 07:43:13 am
« on: May 11, 2003, 08:56:28 am »
Next step then guys!!
I`ve got the thing up and running (thanks to tom61`s help, cheers m8)
I can now see the start screen of arcadeos with the list of games on my hanterex 9200. Problem is, when I try to run a game I get the error message: error 14F in the vesa call 4f06/02 (set scan line length)
I am using on board video so I am not sure whether the vga set up I have will work with my monitor but I thought it`s worth giving it a try! Do I assume that as I am getting a good picture with the arcadeos front end that it will work with mame?
Anyone have any ideas?
thanks in advance
pete
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:error 14F in the vesa call?
« Reply #1 on: May 11, 2003, 04:56:05 pm »
You probably need Sci-Tech Display Doctor for DOS then. Your onboard video probably doesn't support VESA well enough for mame, and SDD fixes that.
peterpiper70
« Reply #2 on: May 12, 2003, 02:00:10 am »
 Thanks for the reply tom61,
Am I better to get a matrix g400 and plug that in? I am guessing it will be much easier to set up and no messing with other programs.
If I purchase one of these will it just be a case of plugging it in to the agp slot and away we go or will I have to start the set up routine over again?
thanks again
pete
tom61
« Reply #3 on: May 12, 2003, 05:19:07 pm »
With DOS and arcadeOS, no more configing should be needed. Not positive how well the G400 handles VESA modes at 15kHz, though. Oh yeah, make sure you get the dual-head version, I think that's the one that works best at 15kHz.
Or you could end the madness now, and shell out for the ArcadeVGA...
