Author Topic: LCD Topgun and mouse HELP!!  (Read 2183 times)
elliotrj
  • Last login:January 08, 2008, 10:19:24 am
  • Now that's a plumber!
« on: December 03, 2007, 07:29:50 am »
Sorry to bother y'all with yet another LCD Topgun post.
I couldn't find the answer to my problem on any other threads.
I'm using MAME32 and have an EMS LCD Topgun with original EMS driver. It works fine as a player one controller (i.e. as a mouse).
My question is simple: is it possible to run a game with the lightgun as player one but leave the mouse available for player two?
I'd really appreciate any help on this. I feel like I've tried everything. :dunno
(P.S. if the answer to this question is already on here somewhere could you direct me to it :D)
« Last Edit: December 03, 2007, 05:11:42 pm by elliotrj »
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
Re: LCD Topgun and mouse HELP!!
« Reply #1 on: December 03, 2007, 09:26:07 am »
What version of mame are you using?  Also can you post the contents of your mame.ini file?  Specifically he "CORE INPUT OPTIONS" and "CORE INPUT AUTOMATIC ENABLE OPTIONS" sections.
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: December 03, 2007, 01:45:46 pm »
My question is simple: is it possible to run a game with the lightgun as player one but leave the mouse available for plater two?
Have you tried enabling multiple mice?  (If you don't have this option in properties, under controllers tab, what version of mameUI are you using?)
You might have to remap both players to use the correct gun/mouse.  This works for multiple normal mice in recent versions, but I'm not sure about with the EMS driver.
Robin
Knowledge is Power
elliotrj
« Reply #3 on: December 03, 2007, 05:21:14 pm »
Hi guys,
I'm using the new MAMEUI32 0.121.
The mame.ini file reads as follows:
<UNADORNED0>
# CORE CONFIGURATION OPTIONS
readconfig                1
# CORE SEARCH PATH OPTIONS
rompath                   roms
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   ini
fontpath                  .
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
# CORE FILENAME OPTIONS
cheat_file                cheat.dat
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
wavwrite
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                1
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
ctrlr
mouse                     1
joystick                  0
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           lightgun
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
# CORE MISC OPTIONS
bios                      none
cheat                     0
skip_gameinfo             1
# WINDOWS DEBUGGING OPTIONS
oslog                     0
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            0
# WINDOWS VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  1
effect                    none
waitvsync                 0
syncrefresh               0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
aspect                    auto
resolution                auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2
# INPUT DEVICE OPTIONS
dual_lightgun             0
I've tried multiple mice but the issue is getting MAME to recognise the mouse and lightgun as two different mice.
It seems to see them as one and the same.
(i.e. Both control player one, but neither control player two.)
Also, what driver are you guys using? Should i switch?
brock.sampson
« Reply #4 on: December 04, 2007, 11:34:44 am »
Try setting
CORE INPUT OPTIONS
lightgun                  1
multimouse                1
I know setting lightgun device to lightgun should make that a 1 by default but I like to set it anyway.  I'm using smog's driver I had problems getting the ems drivers to load.  I haven't had any problems with my dual light guns and trackball acting independently.  Have you tried to reset the control settings on a game manually?  It might be worth deleting the cfg file for a gun game and starting fresh.
elliotrj
« Reply #5 on: December 04, 2007, 03:30:32 pm »
OK this is just getting weird. :dizzy:
I now have a situation where the lightgun controls player two as requested.
But the mouse controls both at the same time!
I've tried every possible combination of controls within the game.
This is the closest I got.
The funny thing is i tried adding a second mouse. I could run the game fine with two players using the two mice.
But every time I introduced the lightgun the mice started acting all strange.
The .ini file is now as follows:
ctrlr
mouse                     1
joystick                  0
lightgun                  1
multikeyboard             0
multimouse                1
steadykey                 0
offscreen_reload          1
joystick_map              auto
paddle_device             mouse
adstick_device            lightgun
dial_device               mouse
trackball_device          mouse
mouse_device              mouse
Maybe I should just try another driver.
brock.sampson
« Reply #6 on: December 04, 2007, 03:44:14 pm »
Seems like a logical next step.  I would try smog's driver I have not had any problems with it.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #7 on: December 04, 2007, 05:59:45 pm »
Agree.  People have had problems with the EMS driver with two players before, but I was hoping that changes since then fixed it.  And since two mice are working without the gun, I'm thinking it's the gun's EMS driver. :-\
Be sure to completely remove the EMS driver before installing SMOG's driver.  The howto is somewhere in the 45 page thread, but I'm not finding exactly where searching with the words I'm using, sorry. :-\
Robin
Knowledge is Power
elliotrj
« Reply #8 on: December 05, 2007, 08:53:13 am »
OK. Thanks for the advice. I'll try out the SMOG driver and get back to you.
elliotrj
« Reply #9 on: December 06, 2007, 08:13:13 am »
Alright. I've loaded up Guncon2 by SMOG. It seems to work a little better.
I ordered a second Topgun this morning. I'm just going to wait til that arrives and set it up as two lightguns, forget about the whole mouse thing.
Thanks again for all the help.
Over and out.  8)
morourke
  • Last login:January 19, 2008, 10:54:38 pm
« Reply #10 on: January 02, 2008, 12:23:39 pm »
I just got two EMS TopGun lightguns over x-mas myself and am having configuration problems. I've read the big 45 page thread but so much of the information seems to be obsolete now.
I'm using MAME 121 and my understand is that the lightguns are now supported as mice.
I've tried the EMS driver, the WinGun driver, and the Gun2Con driver. The EMS didn't seem to work, the WinGun driver has EXCELLENT calibration but MAME wouldn't recognize the trigger, and the Gun2Con drivers works but the calibration isn't very good.
Does anyone know how to get the WinGun driver working with MAME? I'd really like to use it.
Also, it is possible now to map the offscreen reload in games like Area51 to the second trigger on the TopGun? The offscreen reload doesn't seem to work that well so I'd prefer to use one of the other buttons on the gun.
Michael
elliotrj
« Reply #11 on: January 08, 2008, 10:19:24 am »
I've been told that there are all sorts of problems with multiple lightguns in MAME 0.121.
Aparently 0.122 is a whole lot more stable. I haven't had a chance to try it out yet.
Also, Smog's Guncon2 driver is the only one i could get any use out of all.
I know it's not much of an answer but it's all i can tell you.
Afterburner
  • Last login:July 27, 2016, 01:02:00 am
« Reply #12 on: January 09, 2008, 11:11:09 am »
Ah...good thread for me as well.
I also got a EMS TopGun for Xmas and have been fiddling with it trying to get things to work well.
I've gotten the EMS driver Gun2Mouse to work, although it isn't the greatest.  It also isn't all that stable under XP, and I have a very clean and trim XP installation.
I have a two trackball setup and those have never been a problem under Mame32 (v.116 I think).  I was able to get the TopGun to work with Mame by unplugging one of the trackballs.
I tried the gun with both Operation Wolf and T2.  All the buttons work just fine, but it was unusable to play the game.  I tried setting the analog gains and digital speeds to the lowest setting, but the sight was just all over the place.
I briefly tried the GunCon2 driver, but my understanding of what to do with it is rather limited.  I'll check out the aforementioned 45page thread for some pointers.
As many have complained, I'm not crazy about the distance I have to stand back from the screen.  I even tried tilting the LED bars trying to move the convergence point a little closer, but no luck.  At 6 feet from the 17" screen, it's not exactly a point and shoot game anymore.
I'll go back and try the GunCon2 driver again.  If anyone can give me the 50-words-or-less explanation of how it works, I'd be very appreciative.
  2-player upright dual trackball / dual 8-way rotary joysticks - built from scratch
