Author Topic: Winuae in mala  (Read 5257 times)
Thulle
  • Last login:November 30, 2007, 10:43:45 am
Winuae in mala
« on: November 29, 2007, 11:22:23 pm »
Is here anyone that can help me i cant get winuae work in mala when i press a game in mala only the settings window of winuae pops up ....
loadman
  • Moderator
    • MaLa
Re: Winuae in mala
« Reply #1 on: November 29, 2007, 11:59:12 pm »
Forget MaLa for a sec....
Winaue can be fiddly
1) You Know you need a separate Wanuae Config file for each game right?
2) If you have Winuae set up correctly then double clicking on the games config file should launch the (no settings window) game full screen.
    If not then:
    A) Launch  Winuae (not via a config file)
    B) Test the game works via Quick Launch
    C) Enter the rom file location into the hardware/ floppy drive section (NOT quickstart)
    D) Under 'Mic-advanced' make sure the show gui on start-up is not checked
    E) Save 'AS' this config under the game name
    F) Quit Winuae and double click the config file you just saved
    Game should now launch ....  If not you have some other setting wrong in Winaue
When you have Winaue sorted
In MaLa ensure you have it configured as per attached pics (obviously your file path will vary but the command line details should be the same.
When you have you amiga game list loaded then right click and refresh list
Enjoy
« Last Edit: November 30, 2007, 12:05:06 am by loadman »
Thulle
Re: Winuae in mala
« Reply #2 on: November 30, 2007, 10:43:45 am »
    If not then:
Enjoy
Okey ... i just wonder how Maximus arcade are working then if i need to set up every game .... i had maximus arcade before and when i had that i just setup the kickstarts and other files but not a configuration each for all the games
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
Re: Winuae in mala
« Reply #3 on: November 30, 2007, 11:06:24 am »
Maximus Arcade is programmed with SPECIFIC emulators in mind (so much that to play some systems you have to use that one emulator) , Winuae being one of them.  Whereas MaLa is an open ended application that allows for much more freedom with the right amount of setup finesse...
From MA's site:
MA will currently manage the following emulators and executables below. The following emulators listed have been successfully tested with MA, although other emulators may be substituted with varying degrees of success.
* Currently configured to only run with the emulator listed.
Commodore Amiga     Winuae     -s use_gui=no -s gfx_fullscreen_amiga=true -0 %file     .uae, .ipf, .adf, .adz, .gz, .dms, .fdi, .zip
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
loadman
  • Moderator
    • MaLa
Re: Winuae in mala
« Reply #4 on: November 30, 2007, 04:30:42 pm »
..Your Welcome :-)
headkaze
  • 0x2b|~0x2b?
Re: Winuae in mala
« Reply #5 on: December 01, 2007, 01:27:21 am »
Maybe you guys need to check out my UAE Config Creator application. It's designed for the TOSEC collection as it uses it's naming convention to place disk span's into the available drives so you can swap in/out floppy's for multiple disk games. You set your emulator's filter to *.uae.
You can download it from here
loadman
  • Moderator
    • MaLa
Re: Winuae in mala
« Reply #6 on: December 01, 2007, 01:39:46 am »
You are a Tool master...  :-)
headkaze
  • 0x2b|~0x2b?
Re: Winuae in mala
« Reply #7 on: December 01, 2007, 02:28:25 am »
Did you just call me a :tool: master?  :o  :laugh2:
loadman
  • Moderator
    • MaLa
Re: Winuae in mala
« Reply #8 on: December 01, 2007, 05:32:21 am »
[Intoxicated] You know it Perth boy [/Intoxicated]  Hic...     :)
headkaze
  • 0x2b|~0x2b?
Re: Winuae in mala
« Reply #9 on: December 01, 2007, 08:26:59 am »
BTW I finished with the PacDrive if you still need it for your Jukebox project :)
loadman
  • Moderator
    • MaLa
Re: Winuae in mala
« Reply #10 on: December 01, 2007, 06:11:18 pm »
Thanks But I already have a spare Pac-Drive, Led-Wiz and MaLa Hardware here on the bench that I can use in my Jukebox  :-)
tuxied
  • Newbie
  • Last login:March 25, 2009, 04:45:31 pm
Re: Winuae in mala
« Reply #11 on: March 22, 2009, 05:48:24 pm »
this thread helpt me out a lot, thanks!
just some info that can be good to others.
winuaebootlog are the log file for winuae. in that i saw that %path% were read as text and not as a variable, and also that %ext% were translated to zip and not uae.
So i got it to work if i used this as command line: -f "%rom%.uae"
