Author Topic: Coin Door LED's  (Read 8067 times)
bent98
  • Last login:February 02, 2019, 03:35:00 pm
  • Hyperspin Moderator
Coin Door LED's
« on: November 28, 2007, 09:45:21 pm »
I would like to replace the stock bulbs on my Happ Coin door(http://www.happcontrols.com/coindoors/40000800.htm)
with some super brights(http://www.superbrightleds.com/) question is which ones do I use and will they fit in the happ coin door sockets?
Franco
Re: Coin Door LED's
« Reply #1 on: November 29, 2007, 04:01:11 am »
You are after a LED bulb with a T 1-3/4 base. Happ do LED replacements for them here or you can get from form superbrights from this page.
bent98
Re: Coin Door LED's
« Reply #2 on: November 29, 2007, 09:37:59 am »
http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=CAR&keywords=&cart_id=8441170.24139&next=50
is that it 2nd from top???
T13 Wedge Base LED bulb
12VDC 6-LED Wedge Base bulb
measure 1 1/8 long by 1/2 inch maximum diameter (194/168 type)
Available in White, Blue, Green, Red, Amber and UV-BlackLight LED
$ 1.99
91-10WB-123R
 Red T 3-1/4 Cluster (3)  12 vdc #161, #194
But it says 161, 194 bulb size and superbright is 194/168
Happ has 4 cluster
Franco
Re: Coin Door LED's
« Reply #3 on: November 29, 2007, 10:11:22 am »
I'm pretty sure the numbers are only to do with the main bulb bodys shape/size. They all have the same wedge base so they will all fit the bulb holder and there is plenty of room behind your coin inserts for the larger diameter bulbs
tomsurfnj
  • Last login:February 11, 2010, 01:12:43 pm
Re: Coin Door LED's
« Reply #4 on: November 29, 2007, 10:42:41 am »
I used multicolor Led from superbright model # RL5-RGB-ACC. I just taped them behind the coin slots. They look great flashing and changing color. I am going to add one under my trackball in the future.
Just remember to follow polarity.
bent98
Re: Coin Door LED's
« Reply #5 on: November 29, 2007, 11:51:34 am »
I also have a question about wiring the coin door with the IPAC does the switch need power? What do I connect to where?
Franco
Re: Coin Door LED's
« Reply #6 on: November 29, 2007, 12:30:07 pm »
Connect the bulbs to a 12v power supply (eg PC PSU). You could also control the lights by a LED WIZ etc but take note those bulbs have a built in resistor designed to work of 12v and the LED wiz supplies 5v so you would require a different lighting solution.
You don't connect the bulbs to your IPAC, you only connect the micro switches on the coin door which register coin drops.
bent98
Re: Coin Door LED's
« Reply #7 on: November 29, 2007, 12:47:49 pm »
I know how to wire the bulbs. I was talking about the micoswitch. There are 3 connectors on each switch. What do I connect where?
Franco
Re: Coin Door LED's
« Reply #8 on: November 29, 2007, 01:39:12 pm »
Ah, apologies.
The three contacts are ground (the one on the side), normally open and normally closed.
Most arcade coin mechs/buttons/joysticks etc use the normally open contact as when the button etc is pressed the circuit is completed.
Daisy chain both of the micro switches grounds and connect them to one of the ground terminals on the IPAC. Then connect a wire to each of the normally open terminals on the micro switches (dont daisy chain them) and run the separate wires to the Coin 1 and Coin 2 terminals on the IPAC.
bent98
Re: Coin Door LED's
« Reply #9 on: November 29, 2007, 02:13:55 pm »
So there is no power going to these switches. I wasnt sure if coin door return was mechinical or electric.
Franco
Re: Coin Door LED's
« Reply #10 on: November 29, 2007, 02:18:23 pm »
Its a mechanical switch that in turn completes an electrical circuit  ;)
But no, its not like say a Coin Controls Sentinel coin mech that requires power.
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Re: Coin Door LED's
« Reply #11 on: November 29, 2007, 04:05:05 pm »
I just made a wiring harness for my coin door led's & run it from my computer power supply
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
