Author Topic: Issues with Golden Tee displaying correctly  (Read 1863 times)
Rob L
  • Last login:December 31, 2007, 04:36:16 pm
« on: November 26, 2007, 10:14:04 am »
I was wondering if someone can help. For Golden tee (and other games that have the same H/V res) I can't get the game to display correctly unless I choose a funky res. If i select 240x240 and set the aspect ratio manually to 1:1 it will just cut part of the image off at the sides so at the start screen part of the G and last E of tee are cut off. 320x240 and does the same thing.
It seems that regardless of what aspect ratio I try and get it to display nothing changes.
I thought that if I selected a res that is higher than the game (ie 320x240 or whatever it is) that it would put it in the middle and blackout the sides but nope.
What am I doing wrong if anything? Why doesn't the aspect ratio thing seem to matter?
I am using the ArcadeVga2 card and a multi sync arcade monitor and am using the settings that it says to use (switch res to fit, no hardware stretch, etc) on the AVGA page.
I also notice this issue to a lesser degree on other games like street fighter 2 which doesn't seem to matter what res I use and aspect ratio I put in and cuts off a bit at the sides.
« Last Edit: November 26, 2007, 10:16:38 am by Rob L »
ahofle
    • Arcade Ambience Project
Re: Issues with Golden Tee displaying correctly
« Reply #1 on: November 26, 2007, 11:47:22 am »
Golden Tee is 384x240, not square.  Try using 384x288 or 392x240 for the resolution.  Same with SF2 which is 384x224.
« Last Edit: November 26, 2007, 11:50:38 am by ahofle »
savj14
  • Last login:April 06, 2020, 07:52:46 pm
« Reply #2 on: November 26, 2007, 12:06:40 pm »
I don't own an ArcadeVGA but I do use Powerstrip and add custom resolutions.
These are the Setting I use:
### Windows video options ###
autoframeskip           0
frameskip               0
waitvsync               0
triplebuffer            1
window                  0
ddraw                   1
direct3d                0
hwstretch               0
# screen                <NULL> (not set)
cleanstretch            none
resolution              auto
refresh                 0
scanlines               0
switchres               1
switchbpp               1
maximize                0
keepaspect              0
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_gamma       1.000000
frames_to_run           0
effect                  none
screen_aspect           4:3
# mngwrite              <NULL> (not set)
scale_effect            none
### Golden Tee 2K Tournament (v5.00) ###
hwstretch               1
cleanstretch            auto
resolution              448x240x0
### Street Fighter II - The World Warrior (World 910522) ###
hwstretch               0
resolution              768x254x0
switchbpp               0
Hope this helps
ahofle
« Reply #3 on: November 26, 2007, 12:18:25 pm »
hwstretch               1
 :dizzy:
savj14
« Reply #4 on: November 26, 2007, 12:51:04 pm »
For some strange reason I could only get it to work with Hardware stretching, but you muight be able to use 384x288 or 392x240 without stretching.
Rob L
« Reply #5 on: November 27, 2007, 10:42:17 am »
Golden tee isn't 200x200? Great that the game info is wrong then since it says 200x200.
Well this explains it then and I am using the 384x240 or something so that's good. I also am using 392x240 for SF2 but I noticed that when not using "switch res to fit" that there is a bit more at the sides that gets cutoff when using switch res to fit. NOt a big deal sicne it is minor but was just curious.
Thanks for the help...yet again.  ;D
ahofle
« Reply #6 on: November 27, 2007, 10:49:47 am »
You definitely want to check the 'switch resolutions to fit' or MAME won't honor your resolution selection (I believe it will just use your desktop res if unchecked).
