Author Topic: getting trackball to work  (Read 1310 times)
Mr Wilson
  • Last login:August 14, 2018, 01:24:44 pm
  • it never ends!!!!
« on: November 23, 2007, 02:05:09 am »
i finally got my 3" happ trackball its got the usb/ps2 connectors plugged it in and it works as a mouse I'm using the mala front end went to options and ticked the 'use mouse' it works for scrolling up and down the lists but it doesn't seem to work on any game I've tried like golden tee, marble madness etc is there any other options i can change
Cheers
Ross ;D
crummy
  • Last login:May 11, 2008, 03:01:58 am
Re: getting trackball to work
« Reply #1 on: November 23, 2007, 02:47:31 am »
I have not done this so don't take my word for it, but isn't there a "-mouse" command line parameter for MAME?
ArtMAME
  • Last login:August 05, 2020, 12:59:17 pm
  • Hey where the ARCADE MACHINES at???
    • Art's Arcade Lab
« Reply #2 on: November 23, 2007, 09:33:03 am »
Yes, you have to enable the mouse controls for use in MAME.  It is just a checkbox in the Controller tab if  you are using MAME32.  If you are using command line MAME, go into the MAME config file and enable the mouse by changing the 0 to 1 in the mouse parameter.  Then save and close the config file and re-launch of refresh MAME.
"Klaatu. .. Verada. ...... Necktie...Nectar...Nickel..."
Mr Wilson
  • it never ends!!!!
« Reply #3 on: November 23, 2007, 12:10:56 pm »
thanks that works great  ;D
