Author Topic: Sega Outrun Connectors  (Read 5200 times)
alexred
  • Last login:June 25, 2025, 04:21:24 pm
« on: November 19, 2007, 04:03:33 pm »
Does anyone know what type of connector is used to connect to a Sega Outrun PCB?  I need to replace one of the power connectors.  They are 10 pin connectors labeled AMP.  The PCB has latches that the connectors slot into.  I have looked at the usual sources and can't find anything close.  They are not AMP-LATCH which is the only connector type I can find that look even close.
TheDriver
  • Last login:December 21, 2008, 04:08:37 pm
Re: Sega Outrun Connectors
« Reply #1 on: November 20, 2007, 09:40:06 am »
Intresting, I was going to ask this very question when I have finished my jamma machine!!! anyway, I am not sure of what kind they are but a quick search on google found a few thing's that look like them (not having any connector's in my cab at all makes it difficult to look at for reference!) from memory the below link is the closest match I can find but apologies if it is wrong:
http://www.action-electronics.com/computerconnectors.htm#Idcfem
Post back if they are correct for future reference.
Regards.
MonMotha
« Reply #2 on: November 20, 2007, 06:23:16 pm »
Identifying connectors without a picture is practically impossible.  Get a GOOD up-close picture (preferably several from different angles).  Use macro mode on your camera.  Be sure to get detailed images of any locking mechanisms, how the contacts connect to the wire/cable, etc.  If you can get a ruler in the pictures, do so.  The pin-to-pin spacing is also important to know; be aware that it is usually a "nice number" in either metric mm or decimal inches, not the traditional fractional inches.
AMP makes TONS of connectors, many of which cross to another manufacturer anyway, so knowing that it's made by AMP doesn't do a whole lot of good, but it does at least give one a place to start.
If it looks like the connector that TheDriver posted, that's a really standard connector.  You can buy them just about anywhere from several manufacturers.  Just look up 0.1" IDC ribbon connectors.
alexred
« Reply #3 on: November 21, 2007, 08:33:07 am »
Thanks TheDriver.  Unfortunately, that is not the correct connector.  I was hoping someone had experience with the wiring and would know offhand what type Outrun uses.  I will break out the camera and take a picture of the connector and header.  I believe the pin spacing is .156, the particular connector I need is rectangular, 10 pin, 2 rows of 5.  What makes the connector unusual is the way it mates with the header which has levers on both sides to secure the plug.  I may just end up using something that fits but doesn't mate.
Thanks,
MonMotha
« Reply #4 on: November 21, 2007, 05:53:22 pm »
From the sound of it, it's probably some sort of Mate-N-Lock. Get a picture.  If it has such a unique latching system, it should be easy enough to identify.
fredster
  • It's all good!
« Reply #5 on: November 25, 2007, 05:27:36 pm »
yeah, they are unique.  I have an old sega board that has lots of them.  It's from an old motorcycle game.
Every Sega I get into sucks.
TheDriver
« Reply #6 on: December 02, 2007, 09:34:32 am »
No news on these yet alexred???? I had another look for them myself as I found a good pinout of the board but only found similar looking connector not the correct one's.
Regards.
alexred
« Reply #7 on: December 03, 2007, 09:40:18 pm »
I have not been able to identify the connectors.  I have purchased a mini outrun harness that has the connectors I need.  So, if anyone needs a harness minus the power connectors or some other pieces let me know.  Here are some pictures of the connectors.  Maybe someone can identify them.
