Author Topic: question about wiring a coin door  (Read 1782 times)
Polokus
  • Last login:May 09, 2003, 01:04:50 pm
« on: May 09, 2003, 01:06:35 pm »
I have bought a cabinet and the last thing i want to do now is wiring the coin door on my ipac if possible?
is there a page or something where i can see how to wire it so that credits appear when i insert a coin ?
thx in advance for the help
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."
Chris
    • Chris's MAME Cabinet
Re:question about wiring a coin door
« Reply #1 on: May 09, 2003, 01:51:19 pm »
The coin switches at the bottom of the coin door are exactly like all the other switches on your control panel, except that they probably have .250 terminals instead of .187 terminals.  Just wire them up like any other switch.
The lights in the coin slots cannot be lit via the I-Pac.  The "standard" way to do this is to connect either the +5V or +12V (depending on your lights) from a hard drive connector on the computer to the coin door lights, or use a separate power supply.
--Chris
--Chris
Polokus
« Reply #2 on: May 09, 2003, 03:20:56 pm »
thx for the reply, it think i'm screwed cause the switches are missing :(:(:(
all ther rest is there
Chris
« Reply #3 on: May 09, 2003, 03:25:01 pm »
The switches are available from Happ for about $4 each... http://www.happcontrols.com/electrical_supplies/42107500.htm
--Chris
--Chris
JLR2000
  • Last login:February 18, 2021, 02:49:16 pm
  • There is NO Sanctuary...
    • WWW
« Reply #4 on: May 09, 2003, 08:14:51 pm »
If Happs still has that $30 minimum for an order, you can try emailing this guy:
sheljk@attbi.com
He usually has all that stuff, cheaper than Happs and no minimum order that I know of....
Chris
« Reply #5 on: May 09, 2003, 10:32:44 pm »
Happs no longer has a minimum order.
--Chris
