Author Topic: sticky pushbuttons  (Read 1265 times)
mastercave
  • Last login:July 07, 2003, 10:48:57 am
  • single player cp only
sticky pushbuttons
« on: May 09, 2003, 12:15:23 pm »
What could cause sticky pushbuttons? I got some new happs ultimate pushbuttons and after a week of playing, one of the buttons is starting to stick slightly. could it be something with the microswitch? or is it just too much hard jamming?
Chris
    • Chris's MAME Cabinet
Re:sticky pushbuttons
« Reply #1 on: May 09, 2003, 12:20:14 pm »
Swap the switch with another button; if the problem moves, it's the switch....
--Chris
hyiu
    • www
« Reply #2 on: May 09, 2003, 12:49:49 pm »
it could be a microswitch problem....
I also have experienced that if the button itself is screwed too tight to the wood.... (that should only happen when you first screw it in...)
is the wood bend by your pounding on the panel ??....
wood expanded ??....
just a guess.....
