Author Topic: would these microswitches work with a sanwa JLF??  (Read 4803 times)
D4RKSL4Y3R
  • Last login:February 22, 2009, 01:12:33 pm
« on: November 18, 2007, 12:17:28 pm »
http://www.coinopexpress.com/products/parts/microswitch/Microswitch_with_Auxiliary_Actuator_2301.html
would these microswitches work with my joystick? (sanwa JLF...) need to buy them so i can wire them to a pcb with no common ground.
also are there any better ones out there that would be better of getting??
thanks
patrickl
  • Yo momma llama
    • PocketGalaga
Re: would these microswitches work with a sanwa JLF??
« Reply #1 on: November 18, 2007, 01:23:02 pm »
You want to buy a few thousand microswitches?
brandon
  • Last login:December 26, 2025, 08:29:45 pm
  • I <3 arcade games.
« Reply #2 on: November 18, 2007, 02:50:56 pm »
Min. Order: 4000
eek.. and those look like the sucky ones that come with X-Arcade parts...  I'd order some Cherry switches from Happs or whoever carries them.. Lizard Lick? Tornado Terry.. Bob Roberts..  everybody should have em right?
Franco
« Reply #3 on: November 18, 2007, 03:10:13 pm »
You could always just sell your JLF and buy a JLW and use the standard independent terminals on that, unless of course you bought a JLF for a particular reason (whick I would be interested to know as im trying to decide which stick to buy myself.)
EDIT: JLF not JTF  ::) Apologies, JTF is a trade outlest near me that I got a card for today, must have it on the brain!   :dizzy:
« Last Edit: November 18, 2007, 03:22:20 pm by Franco »
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #4 on: November 18, 2007, 03:38:15 pm »
you need Omron microswitches V series
http://www.omroncomponents.eu/home/products/Switches/Microswitches/Unsealed/V/
do not buy cherry. they are soft. JLF need medium or hard microswitches 100-200g.you can use honeywell also W/O plain lever
http://sensing.honeywell.com/index.cfm/ci_id/140301/la_id/1/pr_id/146530.htm
D4RKSL4Y3R
« Reply #5 on: November 19, 2007, 04:00:48 pm »
m8 you are awesom! just what i was looking for!
thanks
o and by the way the reason i dont want to go for the JLW is becouse it has a longer stick (jncreased throw) and is a bat top- its a shooter stick not a fighter stick.
iam lookingt at buyin a semisu LS 32- this have no pcb right? but the LS 32 1 does?)
« Last Edit: November 19, 2007, 04:34:06 pm by D4RKSL4Y3R »
brandon
« Reply #6 on: November 19, 2007, 05:23:07 pm »
You can get the JLW in ball top or bat top.. but everyone does seem to think the JLF is better for fighters.  I'm about to order one of each and try them out.  I like the rotating restrictor on the JLW.. not sure why they didnt design the JLF that way...
kowal
  • Suzo 4ever
« Reply #7 on: November 20, 2007, 09:42:05 am »
JLW 7mm
JLF 7,5mm
he has shorter throw:) stick is higher but angle is smaller (JLW 7degree, JLF 8degree)
main difference then spring: 350g-JLW, 210g-JLF
I will JLW+ GT -0 to fighters
japan version JLW balltop has short throw 5-6mm. only Euro/US version has medium throw.
brandon
« Reply #8 on: November 20, 2007, 11:12:14 am »
I didnt quite understand what you meant on that..  Do you agree that the JLF is better for fighters and JLF better all around?  or is it a matter of preference?   I just like the rotating restrictor of the JLW.. but I've never used one. I might hate it :)
kowal
  • Suzo 4ever
« Reply #9 on: November 20, 2007, 12:18:07 pm »
GT-0 is circle restrictors for JLW, I play on it and this is the best mechanical (microswitches) joystick for me.
surely its matter of preference, but - seimitsu LS32/LS40/LS56 is very similar  than JLF and work better (fast centring to center, fast engage)
brandon
« Reply #10 on: November 20, 2007, 01:59:53 pm »
ahh.. I see :)  how about the octagon restrictor for JLW have you tried them?
D4RKSL4Y3R
« Reply #11 on: November 22, 2007, 04:07:14 pm »
i decided to go with a semitsu LS 32 becouse of the indepenent microswitches and i prefer a shorter stick and throw
