Author Topic: Drilling locks  (Read 5643 times)
ncflagg
  • Last login:January 18, 2024, 05:20:30 pm
  • Oh, yeah. Idaho IS right next to Iowa.
Drilling locks
« on: November 12, 2007, 05:39:16 pm »
I have a Neo Geo that I haven't been able to find the keys for. The marquee has a lock on it. Do I drill it? How is this specifically accomplished? Do I just drill holes in the middle of the lock til it comes loose?
Q*Bert_OP
  • Oh yes, we did!
Re: Drilling locks
« Reply #1 on: November 12, 2007, 05:42:38 pm »
The factory locks on neo's are openable if you stick a large flathead screwdriver in it and twist really hard...
Ken Layton
  • Guru
  • Technician
Re: Drilling locks
« Reply #2 on: November 13, 2007, 12:06:46 pm »
The dedicated Neo's had that lock all keyed alike to National Cabinet Lock key number C-413A (extremely common).
More Cowbell
  • That's just dumb!
Re: Drilling locks
« Reply #3 on: November 13, 2007, 04:59:13 pm »
If you're going to drill it, just hope to get lucky. I have had some that practically fell apart when I drilled into it and some that seemed like Fort Knox. Do some drilling, then crank with a flat head screwdriver, repeat until open. Vacuum up the shavings or you'll be getting slivers in every bit of exposed skin on your body.  :'(
I've got a fever...
Dartful Dodger
  • Newer isn't always better.
Re: Drilling locks
« Reply #4 on: November 13, 2007, 05:26:17 pm »
If you have a similar key for a different cabinet you can try lock bumping.
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
Re: Drilling locks
« Reply #5 on: November 13, 2007, 05:38:39 pm »
I've only had to do this once, but it was pretty easy.  Just make sure your drill isn't an overblown screwdriver and you should be okay.  Make sure you use either a nice drill bit or one you can throw away after though.
knave
  • Last login:September 12, 2025, 11:45:46 am
Re: Drilling locks
« Reply #6 on: November 13, 2007, 06:00:40 pm »
On my neo-geo I think you can unscrew the marquee retainer on the top, then get to the nut that holds on the lock.  No drilling then.
Re: Drilling locks
« Reply #7 on: November 13, 2007, 10:07:24 pm »
I've drilled tons of locks... if you have a decent drill they open like candy.
Don't be concerned about shavings in your skin... be a lot more concerned about metal fragments falling on the PCBs.  They can kill it next time you power up.
ncflagg
Re: Drilling locks
« Reply #8 on: November 14, 2007, 04:46:42 pm »
Thanks, for all the advice. I'll let you know what I find...
Re: Drilling locks
« Reply #9 on: November 14, 2007, 05:22:31 pm »
meh if yours is like mine just reach in through the back and unscrew that screw that the latch is catching and it'll open.
« Last Edit: November 16, 2007, 11:05:51 am by Malenko »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Drilling locks
« Reply #10 on: November 16, 2007, 01:17:27 am »
And wear safety glasses!  Metal shavings can get in your eyes, and then its a problem if you ever need an MRI in the future.
NO MORE!!
Re: Drilling locks
« Reply #11 on: November 16, 2007, 09:07:06 am »
It's a problem immediately, I'd think, since they're often very hot and sharp.
RayB
  • There's my post
    • RayB.com
Re: Drilling locks
« Reply #12 on: November 17, 2007, 03:11:19 pm »
*sigh*
You can get micro sized shavings into your eye... You might not even feel it. But even at that size it's a danger if you get an MRI. So better to be safe.  Capiche?
NO MORE!!
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Drilling locks
« Reply #13 on: November 17, 2007, 07:18:02 pm »
Yeah, if you can get in the back.  But if you need the keys to get in the back...
Re: Drilling locks
« Reply #14 on: November 17, 2007, 08:23:35 pm »
A person who speaks of things that are not 100% parallel to your thoughts is not necessarily having a problem comprehending yours.  If we all brought the exact same thought to the table there wouldn't be any point in sitting at it.
Tu me comprends?
RayB
  • There's my post
    • RayB.com
Re: Drilling locks
« Reply #15 on: November 18, 2007, 05:19:30 pm »
Tu me comprends?
Your post implies one would FEEL anything hitting their eye, invalidating my point. I was clarifying that you wouldn't necessarily be free and clear just because you didn't feel anything hit your eyes.  Stop being such a post-whore.
NO MORE!!
ncflagg
Re: Drilling locks
« Reply #16 on: November 19, 2007, 12:16:20 am »
Yes, I have the back off. I was able to get a philips in and remove the screw-latch easily. Thanks, Malenko and everybody else.
I have have another slightly shorter cab with the same problem. Haven't tackled that one yet.
northerngames
  • Trade Count: (+18)
Re: Drilling locks
« Reply #17 on: November 26, 2007, 09:28:58 am »
also cutting a "+" shape and prying it apart with a flathead and a dremel tool with cut off wheel should work.
