Author Topic: Pac-Drive vs. Led Wiz  (Read 3221 times)
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« on: November 09, 2007, 03:15:53 pm »
Hello,
I'm in the middle of a project and wondering what would be a better Led Driver Board.
I plan on using Mala for the frontend. All I really want to do is light up the buttons for the game selected that will be used for that game and maybe a little attract mode for when the game is idle. I have a bunch of super brite led's to use and I didn't want to get into having to install a resistor for every Led. Lighting around 30 buttons or so.
Any thoughts are greatly appreciated.
Keg
loadman
    • MaLa
Re: Pac-Drive vs. Led Wiz
« Reply #1 on: November 09, 2007, 05:01:40 pm »
If the LED's you have don't have resistors tacked onto them you are going to have to install a resistor for every LED no matter what board you choose.
Both boards will do what you want in MaLa (and in GameEx)
Basic difference Pac drive is smaller and cheaper but only 16 LEDS, The  Led-Wiz supports 32 LEDS & varying Led light levels.
« Last Edit: November 10, 2007, 01:42:40 am by loadman »
kegger
« Reply #2 on: November 09, 2007, 11:46:01 pm »
Thankyou Loadman for your help.
Time to break out the old iron for this one. :P
Keg
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
« Reply #3 on: November 10, 2007, 02:00:29 am »
and 2 Pac-Drives used in parallel with Mala has ... um ... an upgrade coming ... I hope .... soon .... pleeeeeaase.  :'(
headkaze
  • 0x2b|~0x2b?
« Reply #4 on: November 10, 2007, 05:53:27 am »
Arzoo's LEDBlinky will support up to 16 PACDrive's and it's going to be released soon, so you can use that in Mala if you want to use more than one PACDrive.
arzoo
  • Robots WILL kill you.
    • LEDBlinky
« Reply #5 on: November 11, 2007, 10:15:36 am »
Just finishing up the documentation... I'll post the update some time later this week.  ;D
By the way, I think the PacDrive only supports up to 4 devices, but Andy (Ultimarc) can do more if requested.
Robots will kill you.
Arcade Addiction
kegger
« Reply #6 on: November 11, 2007, 11:03:39 am »
Thankyou everyone for their input .
Arzoo Thanks and I will keep an eye out for your release.
Keg
