Author Topic: GGG's NovaMatrix marquee light  (Read 11037 times)
Tiger-Heli
    • Tiger-Heli
Re: GGG's NovaMatrix marquee light
« Reply #40 on: November 10, 2007, 04:45:57 pm »
Fozzy - Reply #34 - Hear, Hear!!! I was going to post almost the identical thing, but you said it perfectly.  Perhaps Will stated in a project thread elsewhere his mistake, but that only came out in this thread after Randy's reply. :cheers:
DK - AFIAK, that would require RGB LED's and I am pretty sure this ships with white ones.  I don't know what would be involved in replacing the LED's with RGB ones or if Randy has (or now has) a planned version with this configuration.  I suspect it would not be very difficult to do, but would likely raise the cost - maybe double it ... ???
« Last Edit: November 10, 2007, 05:06:14 pm by Tiger-Heli »
BobA
  • What Me Worry?
« Reply #41 on: November 10, 2007, 04:58:56 pm »
superbrightleds.com has 12 inch RGB LED light bars.  Looks like descrete LEDs  36 on a 12 inch strip.
Led LINK
« Last Edit: November 10, 2007, 05:00:53 pm by BobA »
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #42 on: November 10, 2007, 07:12:24 pm »
Led LINK
Those things are terrible. I hooked one up to 110v and it died. :(
BobA
  • What Me Worry?
« Reply #43 on: November 10, 2007, 07:28:48 pm »
That is because you let the Magic Smoke out of the LEDs. ;D
Donkey_Kong
    • CNC Machines
« Reply #44 on: November 10, 2007, 08:29:12 pm »
Sounds like it's pretty much way outside of my ability level then. If it doesn't involve pushing a button, or pulling a string I'm pretty much useless.   :D
It would be cool, but probably no demand. My marquee is one of my wifes carvings. I'm going to inset this thing a bit and light it from the bottom front lip of my marquee with Randys NovaMatrix. Thats why I would like to change the colors sometimes...Problem is this is a very untraditional marquee and the demand for color changes on this product will be very little. Unless someone could think of a reason for Randy to use RGB's on this product...He would have one sold for sure! :)
ARTIFACT
« Reply #45 on: November 11, 2007, 01:25:51 am »
I love mine!
My cab is on all day sometimes, and the light never gets hot.
Looks great
thank you GGG :)
SavannahLion
« Reply #46 on: November 11, 2007, 10:46:37 am »
What about EL wire? Purchase three colors in the length you need and the appropriate support hardware and you have your RGB coloring. I've seen systems online that support 3v, 5v, and 12v power configuration. They use converters which up the voltage before hitting the EL wire. If you want it controlled by an LED-Wiz, you'll need a relay depending on where in the power system you install.
Level42
« Reply #47 on: November 11, 2007, 04:39:17 pm »
Fozzy: 100% agreed. Will left out his mistake in his first posting. That was a much bigger mistake than the actual wiring mistake.
« Last Edit: November 11, 2007, 04:41:32 pm by Level42 »
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #48 on: November 11, 2007, 06:32:20 pm »
That RGB strip BobA linked a few posts up looks like what you need.
Anubis_au
  • Last login:January 15, 2023, 10:12:32 pm
  • Ever danced with the Devil in the pale moonlight?
« Reply #49 on: November 11, 2007, 07:49:23 pm »
At any point along my build if I didn't understand how to do something I used the oceans of resources available here to answer my question.
I think that's why you never fried a GGG marquee light, and this bloke did :P
Tiger-Heli
    • Tiger-Heli
« Reply #50 on: November 12, 2007, 08:07:20 am »
Agreed!
Donkey_Kong
    • CNC Machines
« Reply #51 on: November 12, 2007, 10:14:44 am »
Wow uh BobA...I didn't realize that link was meant for me, even after initially looking at it. I feel so dumb...
BobA link over my head...
FrizzleFried
    • Idaho Garagecade
« Reply #52 on: November 12, 2007, 10:16:32 am »
Funny thing is that if Will had just stopped flapping for a minute and actually TOOK MY OFFER, I'd have happily Paypaled him $20.00 that he could have spent on Ultimarc's lighting system.  Oh well...
EDIT: On second thought...maybe we should take up a collection and buy a brand new GGG light for him,  get the molex connector... someone could go by his house and WIRE THAT THING RIGHT UP FOR HIM and THEN maybe he'd give a glowing (no pun intended) review of the GGG part?
XyloSesame
  • Last login:September 17, 2024, 05:57:04 pm
  • the creepy prince guy...
    • The Nightingale Theater
« Reply #53 on: November 12, 2007, 10:25:01 am »
So let me get this straight:
I've got a NovaMatrix in my parts closet waiting for my cab to magically appear.
And I should splice it directly to my power supply, right?
If done correctly, the part will fry, Randy will give me a $5 credit, you will give me $20, and the community will come to my house and wire everything up for me??
Man, I love this place.
Tiger-Heli
    • Tiger-Heli
« Reply #54 on: November 12, 2007, 10:38:19 am »
No, no, no!!! You got to wire it to house current - 100 VAC.  If you splice it to the power supply, it might get 12V and work properly and you'd be out-of-luck!!!  :laugh2:
FrizzleFried
    • Idaho Garagecade
« Reply #55 on: November 12, 2007, 10:51:17 am »
We are a GIVING bunch aren't we Xylo?
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #56 on: November 12, 2007, 12:14:17 pm »
Well, be prepared to never let the conversation die well after it has been ran into the ground and had the weekend to go away.  He'll be sure to get some pointless jab in just for good measure so we don't forget he's here.
mountain
  • Trade Count: (+9)
    • Mountain Jukeboxes
« Reply #57 on: November 12, 2007, 01:22:40 pm »
This thread reminds me of a customer I had years ago when I installed car stereos.
The guy comes in, buys a stereo and leaves. The next day he comes back in.
Me: “Hey, how’s the new radio?”
Customer: "I was hoping to pick out a new one"
Me: “Why, what’s wrong?”
Customer: “That thing is a piece of crap!”
Customer: “What's wrong!? Man, I wired that thing up, like, 5 different ways, and it still didn’t work. Show me one that's a little easier to install?”
  :dunno
