Author Topic: Game Problem  (Read 4155 times)
apples
  • Last login:November 16, 2007, 07:23:38 pm
Game Problem
« on: November 08, 2007, 03:16:31 pm »
Hi all, i have just signed up and i must say i'm liking the site, good work.
Now to my problem, i recently bought a jamma arcade from eBay with a tumble pop PCB, all is fine except when i connect my Street Fighter 2 PCB then the screen is all over the place as if the V-Hold needs adjusting, only problem is i cannot find it on the rear of the monitor (which is a Mid Polo 20" Hantarex) i adjusted a green nob, red nob and a further 2 red nobs but all they seem to do is adjust the brightness & colour.
Can anyone give me any clues as to what to do, i'm new to all this jamma business and bought the machines for my 7yr old.
SirPeale
  • Green Mountain Man
Re: Game Problem
« Reply #1 on: November 08, 2007, 03:29:06 pm »
Not familiar with the first game, but it sounds like a sync issue.  Perhaps one game is standard res, and the other medium?
Kevin Mullins
    • Me on Myspace
Re: Game Problem
« Reply #2 on: November 08, 2007, 04:14:58 pm »
There should be a knob for H FREQ and H PHASE.
There's a small board that plugs into the rear area of the monitor chassis with several pots on it, it may have a cable plugged into it's place so that the board could be relocated towards the front of the machine.
apples
Re: Game Problem
« Reply #3 on: November 10, 2007, 05:30:05 am »
Thanks for the replies,
I've searched everywhere inside the machine but still cannot find the H Feq or familiar nobs, i'm stumped  :'(
grantspain
Re: Game Problem
« Reply #4 on: November 10, 2007, 02:17:28 pm »
i think you will find the adjustment control board may be mounted via an extension lead either in the monitor bezel area,under the cp or inside the coin door
if you take some photos of the back of the monitor we can tell which to adjust
it sounds to me that you are adjusting the colour drives on the neck card
apples
Re: Game Problem
« Reply #5 on: November 11, 2007, 05:31:07 am »
Thanks for the reply mate, i followed some wires that were plugged into the rear of the monitor and hey presto there were the controls  ;D
What i want to know now is, the volume control on my SF PCB doesn't work, do i need a new PCB or can these volume controls be repaired?
grantspain
Re: Game Problem
« Reply #6 on: November 11, 2007, 05:49:55 am »
sound problems can be down to many things,missing voltage/wrong software settings/wiring incorrect or sound generator circuit of the game board
first check if another game gives you sound,that will then prove voltage and wiring is correct.
then check all the dil switches are what they should be(i don't think this applies with your game board though)
apples
Re: Game Problem
« Reply #7 on: November 11, 2007, 08:17:32 am »
I connected my tumble pop game and the volume adjusts no problem, connected SF2 again and the volume wont adjust and it's very loud, i haven't a manual for the PCB so not sure whether the dil switches are in the right place or whether they would make a difference
Kevin Mullins
    • Me on Myspace
Re: Game Problem
« Reply #8 on: November 11, 2007, 09:37:49 am »
What version of SF2 do you have?
(Alpha, CE, Turbo, etc)
I assume you have tried the Vol up and Down switches on the pcb case itself then?
Does your cabinet have a "test" switch to get into the menu?
Were you able to adjust your video sync problem?
apples
Re: Game Problem
« Reply #9 on: November 11, 2007, 10:19:46 am »
Hi Kevin,
I was able to adjust the video sync yes, i found the H freq etc buttons, SF2 is version Champion Edition, the only test switch i can see is on the coin mech to enter credits, the volume control was on the actual game PCB think it's labelled VR1? same as tumble pop but the volume control worked on that but not SF.
Kevin Mullins
    • Me on Myspace
Re: Game Problem
« Reply #10 on: November 11, 2007, 10:48:01 am »
So that "test" switch only adds credits?
(just want to clarify)
There should be an actual TEST switch that when you put it in the test position and THEN turn your machine on it will bring up some menus and such.
I just want to see if your machine has that wired in already, if not then it can be added to the JAMMA harness pretty easy. It might open up some volume options, etc.
apples
Re: Game Problem
« Reply #11 on: November 11, 2007, 10:52:33 am »
That's correct, i haven't got an actual Test switch that brings up a menu etc
Kevin Mullins
    • Me on Myspace
Re: Game Problem
« Reply #12 on: November 11, 2007, 10:57:55 am »
OK, now that we know what version you have, there looks like a dipswitch that can be turned on and then turn the machine on to bring up the menu.
DIP SW C - switch number 8
Not sure if the dips are labeled on the board A,B,C, but there is a diagram in the manual...... it's the only one that appears to use switch number 8. So if you're unsure which one it is, try each one at a time.
PS - SF2 CE Edition Manual
« Last Edit: November 11, 2007, 10:59:36 am by Kevin Mullins »
apples
Re: Game Problem
« Reply #13 on: November 11, 2007, 11:16:30 am »
Thanks for that, i now have test menu but no volume, the options i have are:
Color
Dip Switch
IO Test
Dot Cloth
Character
grantspain
Re: Game Problem
« Reply #14 on: November 11, 2007, 11:26:14 am »
sounds like the vol pot is broken if you get sound but no adjustment
Kevin Mullins
    • Me on Myspace
Re: Game Problem
« Reply #15 on: November 11, 2007, 12:12:36 pm »
Yup, that was my next suggestion is that the pot is bad since the sound does work, just not adjustable.
I was just hoping maybe there was a sound menu like on some other SF2 boards that he could adjust to work around it. But it doesn't look like he has that option.
And I'm assuming there is no other sound pot built into the cab itself then as well. (?)
(coming from the JAMMA harness)
apples
Re: Game Problem
« Reply #16 on: November 11, 2007, 02:00:34 pm »
I was thinking the sound pot as well, there's no other vol control inside the cab :( can these sound pot's been reoaired or do i need a new game board?
grantspain
Re: Game Problem
« Reply #17 on: November 11, 2007, 02:30:57 pm »
someone a good soldering skill can change that pot easy,2 min job
my capcom gameboard has a 2.2k pot for the vol
apples
Re: Game Problem
« Reply #18 on: November 11, 2007, 02:36:29 pm »
That's some good news, any idea where i can buy the pot from?
grantspain
Re: Game Problem
« Reply #19 on: November 11, 2007, 02:44:41 pm »
U.K or U.S?
apples
Re: Game Problem
« Reply #20 on: November 11, 2007, 02:47:21 pm »
U.K
grantspain
Re: Game Problem
« Reply #21 on: November 11, 2007, 03:39:01 pm »
ebay
maplins
c.p.c/farnell
rs
apples
Re: Game Problem
« Reply #22 on: November 11, 2007, 04:40:50 pm »
Is it called a sound pot? as i've searched maplin & rs but nothing listed
grantspain
Re: Game Problem
« Reply #23 on: November 11, 2007, 05:16:21 pm »
« Last Edit: December 02, 2007, 07:51:44 am by Peale »
grantspain
Re: Game Problem
« Reply #24 on: November 11, 2007, 05:17:33 pm »
« Last Edit: December 02, 2007, 07:52:10 am by Peale »
apples
Re: Game Problem
« Reply #25 on: November 11, 2007, 06:10:36 pm »
Thanks Grant, much appreciated  ;D
apples
Re: Game Problem
« Reply #26 on: November 15, 2007, 11:54:39 am »
Sorry to bring this back up again, but i'll be popping into maplin tomorrow to buy a potentionmeter the only problem is on their website there are a few to choose from:
10k, 5k, 1k, 500R & 100R
Which one do i need for the volume?
grantspain
Re: Game Problem
« Reply #27 on: November 15, 2007, 12:03:09 pm »
try the 1k ,i don't think its perfectly correct but it should work
Kevin Mullins
    • Me on Myspace
Re: Game Problem
« Reply #28 on: November 15, 2007, 12:23:33 pm »
Yeah, the 1K or the 5K...... just depends on how sensitive you want it.
apples
Re: Game Problem
« Reply #29 on: November 15, 2007, 01:47:22 pm »
Thanks guys, help very much appreciated  ;D
