Author Topic: Controller not working with MaLa once game launches  (Read 2689 times)
dgnr8
  • Last login:November 14, 2007, 12:40:51 pm
« on: November 06, 2007, 09:33:48 pm »
I just downloaded MaLa & have been pleased with it's use as a Front End over MAME32. I got it all configured to match what I wanted; it recognizes my controller's buttons within the Options menu and I am able to scroll through & select games using the buttons I mapped.
HOWEVER, once a game actually starts, none of my controller buttons are recognized. If I hit Tab to open the menu & go in to the controls, none of my button presses are registered. If I switch over to MAME32, my same controller works great.
Is there something I need to do to get MaLa to recognize & use my controller once the games start? I am using a GPWiz to connect my controller to my PC via USB.
loadman
  • Moderator
    • MaLa
Re: Controller not working with MaLa once game launches
« Reply #1 on: November 07, 2007, 04:13:06 am »
For a start don't use mame32 with a FE.  It sometimes has problems.  :-[
Use command line mame.
dgnr8
« Reply #2 on: November 07, 2007, 09:46:02 am »
No worries, I'd read that and that isn't what I'm doing.
I've got 2 separate folders altogether on my PC; one has the command line MAME with MaLa and the other has MAME32. No ROMS, INIs, etc are shared between the two; they are separate in every way I can tell.
For comparison sake, I was simply saying that I know the problem isn't with my controller because (A) it works for scolling through & selecting the game and (B) the exact same game works fine if I launch it in MAME32.
dgnr8
« Reply #3 on: November 07, 2007, 12:22:07 pm »
With help from RandyT (thanks again) I got it working. Even though I had enabled the joystick for the MaLa GUI, it apparently was not enabled by default for mame launched by MaLa. When using MAME32 this is done by default so I didn't need to "configure" mame to use a joystick.
By going into the options and clicking "Configure" for my mame.exe, all I needed to do was enable the joystick in there under the Controller tab. Seems simple enough, not sure how I missed that but hopefully someone else searching the forums will come across this post and save them self the time I wasted.
