Author Topic: Need template for over under coin door  (Read 1095 times)
steveh
  • Last login:January 29, 2024, 09:33:42 am
    • thecrazysteve.com
« on: November 04, 2007, 02:28:28 pm »
I have 2 over under coin doors, and i need a template so i can cut the front of my cab.  if any one has one, or can tell me when i can find one that would be great.
i am pretty sure this is the door i have (or at least something very similar to it.
http://www.happcontrols.com/coindoors/40003800.htm
thanks in advance.
Red 5
  • Last login:January 08, 2021, 10:30:51 am
  • Do something stupid and we will make you famous
Re: Need template for over under coin door
« Reply #1 on: November 04, 2007, 02:34:56 pm »
You could use the hole cutout diagram on the page that door is on.
http://www.happcontrols.com/coindoors/40003800_exploded.htm
Jon
« Last Edit: November 04, 2007, 02:36:41 pm by Red 5 »
I accept CASH, Hostages and Gold Krugerrand
steveh
    • thecrazysteve.com
« Reply #2 on: November 04, 2007, 02:38:52 pm »
i am really looking for something i can print out and tape to it, and just cut it out that way.
Red 5
« Reply #3 on: November 04, 2007, 02:41:17 pm »
Ok?
Jon
Red 5
« Reply #4 on: November 04, 2007, 02:59:53 pm »
I had to go PDF on it but if you print 1 to 1 it should work.
I left the measurements on there so you could check it.
Have Fun,
Jon
edit - I really need to learn grammer
« Last Edit: November 04, 2007, 03:31:37 pm by Red 5 »
steveh
    • thecrazysteve.com
« Reply #5 on: November 04, 2007, 03:57:25 pm »
thank you i think this should work fine :)
