Author Topic: New VECTOR GAME Emulator (AAE)  (Read 123757 times)
Tiger-Heli
    • Tiger-Heli
Re: New VECTOR GAME Emulator (AAE)
« Reply #40 on: November 13, 2007, 09:33:25 am »
When I try to run AAE the sceen pops up for a split second and then goes away, i think it says please wait,  I looked in the log and the only thing that looked off was FSAA was disabled,  would this cause my problems
I assume you are running it from a command line - try double-clicking AAE and launching the game from the GUI.  You should see an error message then.  My guess would be either bad roms or bad rom paths.
Disabling FSAA won't cause it, I had to do that also, and it works for me.
Chunce DeLeone
  • Last login:August 16, 2012, 02:58:11 pm
« Reply #41 on: November 13, 2007, 10:10:54 am »
I've tried it from CMD line and the exe,  and both have a quick flash and then nothing,  also in the log the Rom path is verified,  however if I have bad roms would that cause this error, I'm not even getting into the gui, not even able to choose a rom, just a quick please wait screen pops up and goes away,   :banghead: :censored:
Tiger-Heli
    • Tiger-Heli
« Reply #42 on: November 13, 2007, 11:27:21 am »
Odd - no it should come up to the GUI whether the ROMS are good or not.
Chunce DeLeone
« Reply #43 on: November 15, 2007, 08:19:44 am »
Maybe its because I didn't register MSVCRT71.dll, and just placed it into the AEE directory?  I tried some different roms and I get a loading screen then it dissapears, its weird.
aae
  • Last login:November 25, 2011, 04:17:25 pm
« Reply #44 on: November 18, 2007, 08:59:07 am »
Chunce,
Are you running XP or Vista? You should get something on the screen no matter what. Can you send the aae.log file to my email address on the webpage?
aae
« Reply #45 on: November 18, 2007, 09:00:29 am »
BTW, Update 5 is now out, and if anyone likes battlezone, or red baron, you need to update to this version!  ;D
Chunce DeLeone
« Reply #46 on: November 19, 2007, 08:45:46 am »
AAE,
I have TinyXP Beast Edition,  I will copy the log and post tomorrow.  thanks
Chunce DeLeone
« Reply #47 on: November 20, 2007, 11:15:27 am »
I forgot sorry, I will paste tommorrow,  this is very important to my cab,
Chunce DeLeone
« Reply #48 on: November 26, 2007, 07:51:08 am »
Keys Save not found! - Setting Defaults
Setting timer resolution to Min Supported: 1 (ms)
Number of supported joysticks: 0
Number of supported games 60
Paths are aae:C:\Vector\aae.ini game:C:\Vector\cfg\aae.ini override val: 0
Starting
Loading configuration information for aae
Configured Mame Rom Path is C:\ROMS\MAME\roms
Available Screen modes for ATI2DVAG
640x480x16-bit color (30 Hz)
640x480x16-bit color (60 Hz)
640x480x32-bit color (30 Hz)
640x480x32-bit color (60 Hz)
720x480x16-bit color (30 Hz)
720x480x16-bit color (60 Hz)
720x480x32-bit color (30 Hz)
720x480x32-bit color (60 Hz)
720x576x16-bit color (59 Hz)
720x576x16-bit color (60 Hz)
720x576x32-bit color (59 Hz)
720x576x32-bit color (60 Hz)
800x480x16-bit color (60 Hz)
800x480x32-bit color (60 Hz)
800x600x16-bit color (56 Hz)
800x600x16-bit color (60 Hz)
800x600x32-bit color (56 Hz)
800x600x32-bit color (60 Hz)
848x480x16-bit color (60 Hz)
848x480x32-bit color (60 Hz)
1024x768x16-bit color (43 Hz)
1024x768x16-bit color (60 Hz)
1024x768x32-bit color (43 Hz)
1024x768x32-bit color (60 Hz)
1152x864x16-bit color (43 Hz)
1152x864x16-bit color (47 Hz)
1152x864x16-bit color (60 Hz)
1152x864x32-bit color (43 Hz)
1152x864x32-bit color (47 Hz)
1152x864x32-bit color (60 Hz)
1280x720x16-bit color (60 Hz)
1280x720x32-bit color (60 Hz)
1280x768x16-bit color (60 Hz)
1280x768x32-bit color (60 Hz)
1280x800x16-bit color (60 Hz)
1280x800x32-bit color (60 Hz)
1280x960x16-bit color (60 Hz)
1280x960x32-bit color (60 Hz)
1280x1024x16-bit color (43 Hz)
1280x1024x16-bit color (47 Hz)
1280x1024x16-bit color (60 Hz)
1280x1024x32-bit color (43 Hz)
1280x1024x32-bit color (47 Hz)
1280x1024x32-bit color (60 Hz)
1360x768x16-bit color (60 Hz)
1360x768x32-bit color (60 Hz)
1360x1024x16-bit color (60 Hz)
1360x1024x32-bit color (60 Hz)
1400x1050x16-bit color (30 Hz)
1400x1050x16-bit color (41 Hz)
1400x1050x16-bit color (60 Hz)
1400x1050x32-bit color (30 Hz)
1400x1050x32-bit color (41 Hz)
1400x1050x32-bit color (60 Hz)
1440x900x16-bit color (60 Hz)
1440x900x32-bit color (60 Hz)
1600x1200x16-bit color (60 Hz)
1600x1200x32-bit color (60 Hz)
1680x1050x16-bit color (60 Hz)
1680x1050x32-bit color (60 Hz)
1792x1344x16-bit color (60 Hz)
1792x1344x32-bit color (60 Hz)
1800x1440x16-bit color (60 Hz)
1800x1440x32-bit color (60 Hz)
1856x1392x16-bit color (60 Hz)
1856x1392x32-bit color (60 Hz)
1920x1080x16-bit color (30 Hz)
1920x1080x16-bit color (60 Hz)
1920x1080x32-bit color (30 Hz)
1920x1080x32-bit color (60 Hz)
1920x1200x16-bit color (60 Hz)
1920x1200x32-bit color (60 Hz)
1920x1440x16-bit color (60 Hz)
1920x1440x32-bit color (60 Hz)
2048x1536x16-bit color (60 Hz)
2048x1536x16-bit color (66 Hz)
2048x1536x32-bit color (60 Hz)
2048x1536x32-bit color (66 Hz)
2560x1600x16-bit color (30 Hz)
2560x1600x16-bit color (41 Hz)
2560x1600x16-bit color (60 Hz)
2560x1600x32-bit color (30 Hz)
2560x1600x32-bit color (41 Hz)
2560x1600x32-bit color (60 Hz)
Current res is number 6
Current res is number 7
FSAA DISABLED!!!!
Max Texture Size supported by this card: 4096x4096
ARB_Multisample Extension Supported
Anisotropic Filtering Supported
Your video card supports vysnc, Excellent!
EXT_Frambuffer Object Supported, good as this is required ')!.
Successful .png upload: error.png
Successful .png upload: info.png
Successful .png upload: buttons.png
Successful .png upload: joystick.png
Successful .png upload: spinner.png
Successful .png upload: settings.png
Successful .png upload: video.png
Successful .png upload: sound.png
Successful .png upload: gamma.png
Successful .png upload: ship.png
Successful .png upload: shipeng.png
Successful .png upload: explosion.png
Successful .png upload: star.png
Successful .png upload: font1.png
8cd5
Framebuffer Complete! A-OK
Finished configuration of OpenGl sucessfully
Opening, aaeres\aaeres.zip
Opening Sample - error.wav
Created AAE Sample - error.wav
Opening Sample - hiss.wav
Created AAE Sample - hiss.wav
Opening Sample - psnoise.wav
Created AAE Sample - psnoise.wav
Opening Sample - flyback.wav
Created AAE Sample - flyback.wav
Opening Sample - opening.wav
Created AAE Sample - opening.wav
Opening Sample - key.wav
Created AAE Sample - key.wav
Opening Sample - idle.wav
Created AAE Sample - idle.wav
Opening Sample - explode1.wav
Created AAE Sample - explode1.wav
Opening Sample - fire.wav
Created AAE Sample - fire.wav
No Game Selected - Running Built In GUI...
MENU SET LINEWIDTH to 2.500000
Closing log
Darth Nuno
  • Last login:May 08, 2024, 04:26:02 pm
  • Namco is God !
    • Arcade Lifestyle / Dragon's Lair Fans
« Reply #49 on: December 14, 2007, 02:53:48 am »
I plan to buy a new video card for testing this emulator. What would be the best model to buy... cheap please, because it'll only to run this emulator (I don't want to run latest PC games....). I don't have a PCI Express slot... only AGP model please  ;)
« Reply #50 on: December 14, 2007, 05:17:44 am »
This looks awesome...I don't think I can use it in my cab (AVGA) which is a shame, but I look forward to trying it on my desktop!
Tiger-Heli
    • Tiger-Heli
« Reply #51 on: December 15, 2007, 06:21:58 am »
I basically posted this info earlier in the thread, but for Nvidia anything newer than an FX5200 should work, for ATI, I think you need newer than a 9550 (verified a 9200 does NOT work and pretty sure a 9250 will not either.)
Both of those are pretty basic and the minimum for not having it halt with errors, but a better card would be recommended.
dmckean
« Reply #52 on: December 30, 2007, 10:25:21 am »
Wow!
This emulator is pretty cool. I've only played Asteriods on it so far but it's the best experience I've had with Asteriods yet! It's not really like a vector but it captures that frantic feel better than the other emulators.
Nologic
  • Last login:November 21, 2008, 03:22:57 pm
« Reply #53 on: January 04, 2008, 03:34:39 pm »
Anyone have links to a proper clrmamepro dat for this? Heh I like to cross my t's and dot my i's. :)
By the way very nice emulator, I look forward to trying out newer builds.
"Pinky, you've left the lens cap of your mind on again." - The Brain
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #54 on: February 27, 2008, 02:36:59 am »
aae did you also author the GL emulators from a few years ago?  If so welcome back.  I'm looking forward to trying this out.  Black Widow is one of my favorite games.  I would love to build a vector only cab too, this could be the reason to do it!
~telengard
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
Tiger-Heli
    • Tiger-Heli
« Reply #55 on: February 27, 2008, 08:35:26 am »
Dat file is here: http://www.logiqx.com/Dats/
And yes, AAE author = bzoneGL author = Asteroids GL author = ...
Ummon
  • Trade Count: (+13)
« Reply #56 on: April 10, 2008, 09:58:39 pm »
I'm just bumping up awareness of this project. A recent update on the homepage shows some nice progress.
Yo. Chocolate.
Stephen Hawking
Farb
  • Last login:July 31, 2024, 03:26:57 am
  • 204,600 in Donkey Kong so far...
« Reply #57 on: May 22, 2008, 09:10:31 am »
This is a very cool project! Has there been any update for joystick button support?
Darth Nuno
  • Namco is God !
« Reply #58 on: July 21, 2008, 11:32:17 am »
Wow... I finally test this *amazing* emulator. I got on the ebay a graphic card only for this project : a gforce 6600, and it's wonderfull  :notworthy: :notworthy: :notworthy:
Many thanks to the author of this emulator  :applaud: :applaud: :applaud:
I really hope you'll improve more games for it, as you did for one  of the best one : Asteroids  :cheers:
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #59 on: July 21, 2008, 12:52:29 pm »
I'm somewhat interested in this project, but it's been a LONG time since the last beta release. I emailed around a week ago with no response. I hope development is continuing and a new release will come soon.
Ummon
« Reply #60 on: July 21, 2008, 04:43:29 pm »
A long while since that last release, but not altogether that long since the latest development update, which looked promising.
Yo. Chocolate.
Stephen Hawking
Darth Nuno
  • Namco is God !
« Reply #61 on: July 24, 2008, 03:49:55 pm »
A very strange thing.
In many games, the refresh rate (when you press F11) shows very strange values  ???
By exemple, Battlezone gives me 40 / 40 fps ?
Space Wars gives me 38 / 38 fps ?
So I presume that is the reason why these 2 games are not so 'smooth' during the animation.
I'm using a 2.6Ghz processor, so It can't be the reason ..
BUT asteroids gives me something 'normal' : 60/60 fps and looks perfect.
Any idea or tips to improve the animation ?
Ummon
« Reply #62 on: July 25, 2008, 10:16:31 pm »
I think those are some he's working on. I did a detailed testing of it and found various issues with many games, which is why I'm not using it yet. Sit and wait.
Yo. Chocolate.
Stephen Hawking
Darth Nuno
  • Namco is God !
« Reply #63 on: September 07, 2008, 01:03:55 pm »
I really hope the author of this great emulator won't give up  :o
The work done until the last version is spectacular (Asteroids is incredibly amazing)  :applaud:
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
« Reply #64 on: September 10, 2008, 04:10:03 am »
Finally updated my cab comp and GCard. I have to say this emu made the job totally worth it! Fantastic. Can't wait to see how far this project goes. But for the love of god WHY NO STARWARS yet! :hissy:
When pixelated clipart just wont do, just call for Betty
88mph
  • Last login:July 30, 2018, 12:17:48 pm
  • I need fuel!
« Reply #65 on: September 11, 2008, 03:33:17 pm »
So I take it that the description of this emulator over at CAESAR is incorrect?  Darn, I was getting my hopes up that AAE emulates Star Wars...
bent98
  • Last login:February 02, 2019, 03:35:00 pm
  • Hyperspin Moderator
« Reply #66 on: September 29, 2008, 08:28:31 pm »
looks like a new version came out!!!
Ummon
« Reply #67 on: September 29, 2008, 08:34:49 pm »
Apparently, yes. Nice.
Yo. Chocolate.
Stephen Hawking
polaris
  • veni vidi congai
« Reply #68 on: September 29, 2008, 08:42:30 pm »
it says star wars is included now.
bent98
« Reply #69 on: September 29, 2008, 10:41:02 pm »
Anyone test yet?
My gefore 280gtx runs it fine, but my ATI X1950XT is having issue.
I have enclosed pics and logs
Havok
  • Trade Count: (+17)
« Reply #70 on: September 30, 2008, 01:06:06 am »
Just grabbed the latest build: Star Wars works perfect for me! Asteroids is a bit slow, but playable, Battlezone is in between, but I am totally loving Star Wars! This is so going on my cab. My test rig is a P4 2.5GHz, 1GB Ram, ATI Radeon 2400HD
waveryder
« Reply #71 on: October 01, 2008, 02:50:01 pm »
Starwars looks just amazing. This is just a fantastic emu! Hope the author keeps workin on it. Just wish I had a starwars yoke to match the fantastic visuals  :hissy:
Just wanted to add specs:
P4 2.8ghz 1gb ram and nvidia 6600
Works fantastic
Ummon
« Reply #72 on: October 01, 2008, 07:09:06 pm »
I have forgotten to set it up. I do have a yoke. Must get a CP built.
Yo. Chocolate.
Stephen Hawking
Ninten-doh
  • Last login:March 31, 2017, 10:37:18 am
  • I promise sweetie, this is my last cab purchase
« Reply #73 on: October 01, 2008, 10:47:33 pm »
So bummed.  I tried installing it, and when I either double-click aae.exe in Windows, or try to run it from the command prompt, I get the same error...
"Application failed to initialize properly (0xC0150002).  Click on OK to terminate the application."
I'm running Windows XP.  Any ideas?
Ninten-doh
« Reply #74 on: October 01, 2008, 11:37:11 pm »
BTW, I'm still on service pack1 with XP.  Could this be an issue because I haven't installed SP2 or SP3?
Ummon
« Reply #75 on: October 02, 2008, 12:31:21 am »
Looking good so far, though I'm having controls set-up issues that are pretty upsetting. Will post later.
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #76 on: October 02, 2008, 02:32:42 am »
Okay, here's some stuff. Comments are a combination of praise and issues. Anything not commented on was either okay or not played :
asteriods deluxe: ---smurfin--- awesome. Transparency and brightness are just killer. Perhaps this game's qualities could be a model for games in this emu.
bzone: KB LEDs off, but still blinking when coined up
bwidow:
- aspect - it's not accurate, though it's interesting, why did you choose that?
 -transparency, particularly of lines on lines, could perhaps be a little better
- flash bug sound is wrong
- controls are still backwards
- game doesn't automatically go to 'start' when coined and start pressed
red baron:
- looks good
- sensitivity at 1 and still too high (I seem to remember this was the same last time).
- KB LEDs off, but still blinking
Star Wars is pretty nice. Good transparency.
Tail Gunner looks good; sorta similar to red baron in quality.
Tempest:
- looks pretty damn good. (Note edit below for neat settings I found.)
- Locks up on level 14 during warp to next level: stops, vector lines go white, and the sound repeat-skips.
- request: need higher mouse sensitivity setting
The Cinematronics games look good.
Some games just look brighter than mame, but not startlingly different: Star Trek, Space Duel, Zektor, Asteroids
GUI suggestion:
- make game settings available from here
- make global settings
- make mouse independent of list; make GUI settings
Overall issues - intermittent, takes emu restart to fix:
- games not starting once coined
- not being able to navigate game menus in general
- controls: when pressing enter, no input for particular keystroke recognized, though menu can still be navigated and tabbed.
- controls: setting, say, 'fire: enter pressed and both it AND 'start 1' go to 'none' and then no keypresses register on 'fire'.
*I kind of forgot to mess with things in these games, but just now I did with Tempest and I got what I think is pretty neat. The settings are:
gamma 0
brightness 0
contrast 3.5
draw lines disable
phosphor trail more
phosphor glow 25
line width 1.1
point size 1
monitor gain 25
« Last Edit: October 02, 2008, 07:00:50 am by Ummon »
Yo. Chocolate.
Stephen Hawking
Ummon
« Reply #77 on: October 03, 2008, 05:27:34 pm »
Just wanted to add: this looks better on a PC CRT than my arcade multisync. The multisync is nice, but the higher resolution of the PC CRT makes for better quality lines, as well as better translucence. The games mentioned above with translucence 'issues' are still the same, but they look better. It's interesting, it seems some colors provide better translucence than others, with the brighter the color the less there is.
« Last Edit: October 03, 2008, 06:00:01 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
aae
« Reply #78 on: October 07, 2008, 07:03:44 pm »
Ummon,
Glad I looked at this again! Thank's for the feedback, and I will try and address all I can in the next version. I am in the middle of rewriting all of the input code, (something I have put off for a while) and should have most of the issues with the controls fixed next release, along with Joystick support.
As to losing the controls for a game, that's an occasional bug that I haven't been able to track down. If you delete the default key config file and the one for the game, it will be fine.
As for Black Widow, it's a little embarassing since that's the game I used to test all of the new atari vector timing code, I'm not using mame's but I think it's pretty accurate nonetheless.
I THOUGHT that was the correct aspect, at least it fits in test mode.  ???
I'll get the controls fixed, I honestly hadn't tested it in my cabinet yet.
Your comments on Tempest upset me a little.  :angry:
I patch all of the protection code out at runtime because my pokey code is a little rough.  I tested the level 14 bug and was CERTAIN I had it fixed. I'll try it again tonight and see if I can reproduce it.
What rom version were you playing?
Thanks!!
Tim
Ummon
« Reply #79 on: October 09, 2008, 06:00:02 pm »
Hey, Tim.
- Black Widow: well, except for the flash/stink bug sound, it seems to run/play fine, it's just the coining up is delayed. The web is circular in yours but in Mame, and in Starcade episodes, it's oval. Doesn't bother me, I was just mentioning it.
- roms: I think I'm using the most current ones for all games tried. It seemed they had to be current.
Yo. Chocolate.
Stephen Hawking
