Author Topic: LEDs in coin door  (Read 1949 times)
SirPeale
  • Green Mountain Man
LEDs in coin door
« on: May 07, 2003, 08:36:13 am »
I've been thinking about using LEDs in my coin doors.
http://www.exabytesystems.com/default.php?cPath=23
Since the rejects are red already, I figured I might use the 11000 mcd ones, as they're far brighter than their white 9000 mcd counterparts.
My question is: would they be too bright?
Unfortunately, although I know how LEDs work, I don't know how to calcutate their brightness.  I know that the higher the mcd, the brighter the bulb, but that's about it.
TazMan
  • Last login:January 26, 2025, 03:30:01 pm
  • It's no easy being green.
    • What is the MAMEtrix?
Re:LEDs in coin door
« Reply #1 on: May 07, 2003, 08:44:21 am »
Are you using a Happ Coin Door?  Even if you're not, does the coin door you're using have a socket for the bulbs right now? On my cabinet I am using LEDs from thes guys SuperBrightLeds.com.  They have the wedge base T3 1/4 and the 4 bulb led is plenty bright enough, plus it has a built-in limiting resistor and you can snag the 12v from your PC power supply
WLED-R4 Red LED bulb
12V Red 4-LED Wedge Base Bulb
$ 1.59
KevSteele
  • Last login:January 20, 2025, 11:29:37 am
  • Retrogaming Media Mogul in Rehab
« Reply #2 on: May 07, 2003, 08:48:06 am »
I used two ultra-bright white LEDs in my coin door lights. They're only a little brighter than the original lights, and much cooler (literally).
Here's a pic:
More pics and details in my "Lazer LED" review:
http://users.adelphia.net/~kevsteele/mame/lazer.html
I picked the Lazer LEDs because they were pre-fitted with a Molex power connector and already had the appropriate resistor wired in (yes, I'm that lazy  ;) )
Kevin
Kevin Steele, Former Editor and Publisher of RetroBlast! and GameRoom Magazine
SirPeale
« Reply #3 on: May 07, 2003, 12:54:52 pm »
$ 1.59
Interesting...that just plugs right into the original socket?
TazMan
« Reply #4 on: May 07, 2003, 01:54:29 pm »
Yep - that is as long as the original socket is T 3 1/4  - which is what Happ uses as default for their coin doors and Illuminated push buttons, which by the way I switched the incandesent bulbs with these leds also.  I actually just used the one bulb T 3/14 leds from them for the pushbuttons
SirPeale
« Reply #5 on: May 07, 2003, 02:47:48 pm »
They're not Happs coin doors.  One's a Williams coin door, the other two are from CoinCo.
KevSteele
« Reply #6 on: May 08, 2003, 08:35:15 pm »
Very cool! Thanks for the URL -- I may just swap out my current LED setup for socketed LED lamps.
Kevin
