Author Topic: Button presses repeating (too sensitive)  (Read 1071 times)
Agent Davis
  • Last login:April 11, 2008, 04:14:41 pm
« on: October 25, 2007, 06:22:11 pm »
Ok, so I've got my 20 awg wire wired up to my ipac.  On a few of the buttons one button press results in 2-3 actual signals being sent.  Example:  Hit my purple button once and I get 3 letter "C"s in my notepad.  I've swapped out the cherry switches on a few, still does it.  I'm sure some of you have experienced this.  Everything is wired where it should be.  Help?
Agent Davis
Re: Button presses repeating (too sensitive)
« Reply #1 on: October 28, 2007, 08:47:16 pm »
Ok, someone has to know what I'm talking about....
FunWithFire
  • Last login:July 07, 2009, 01:17:30 am
« Reply #2 on: October 28, 2007, 09:53:10 pm »
Do you have a solid ground? Maybe it's jittering on you when you hit a button.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: October 28, 2007, 09:56:35 pm »
Maybe adjust your key repeat rate under Control Panel/Keyboard.  :dunno
What operating system, front end, etc are you running?
tk_42_1
  • Last login:November 17, 2010, 03:43:24 pm
  • I suggest a new strategy...Let the Yorkie win!!!
« Reply #4 on: October 29, 2007, 12:09:15 pm »
I agree with FWF, check your grounds.  I had similar problems with multi keyhits and other keys not working on my first CP.  Checked all my grounds and found a bunch of bad ones (bought a new crimper before replacing whole ground harness.)
Agent Davis
« Reply #5 on: October 29, 2007, 04:38:16 pm »
Thanks guys, I believe it to be loose grounds as well.  I appreciate the feedback.
