Author Topic: Scanning artwork  (Read 1665 times)
SavannahLion
Scanning artwork
« on: October 25, 2007, 12:36:19 pm »
If I find I have a marquee or another piece of art that I find isn't available at the repositories that I can find, what's the correct process to get them scanned and uploaded?
Scanner settings? File preferences? Anything else I might've forgotton to ask about?
zorg
Re: Scanning artwork
« Reply #1 on: October 26, 2007, 04:53:35 am »
Scan it in at least 300dpi.
I personaly used to set  color correction to OFF
if the piece you want to scan is bigger than the scan (I guess it is), then  scan it with overlap beetween consecutive scans, in order to be abble to stich the piece together.
format of the files, any loseless format, eg png tiff (avoid jpg)
I'm on the planning stage
SavannahLion
« Reply #2 on: October 26, 2007, 03:44:07 pm »
Is there a maximum or is 300dpi the preferred?
Anything else like Descreening, edge smoothing, etc? Or should it all be off?  ???
No problem. :)
