Author Topic: How do you play IKARI WARRIORS (mame)?  (Read 16405 times)
ARTIFACT
« on: October 23, 2007, 11:14:06 pm »
... I understand that this game had a "different" control setup (joystick with button?)
MaLa reports it as a "paddle" game, but my spinner does nothing
See my project thread for pics of my cabinet and CP.
I have:
2 x U360 joysticks
2 x 6 game buttons
2 x Start buttons (obviously)
1 x trackball (Happ 3" illuminated)
1 x Turbo Twist 2 spinner
Soooo... I just want to play even 1 player...
How can I configure it so I can control the fire direction?
Right now I can control position, fire with button 1, but it always fires "up" (forward)
thanks!
csa3d
  • Will game for food
    • Galaxian Mame Conversion
Re: How do you play IKARI WARRIORS (mame)?
« Reply #1 on: October 23, 2007, 11:16:07 pm »
I remember twisting the original joystick (which was sorta clicky) to set the orientation of the firing.  I wonder if you can configure the spinner to do that.   :dunno
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
« Reply #2 on: October 23, 2007, 11:32:29 pm »
Ikari Warriors is one of my all time favorite games ever.  It's probably the only game I ever actually finished.  And yes, the original game you could rotate the handle of the joystick to determine where you aim.  I know you can buy joysticks like this but don't know what they are called.
You could probably rig up a spinner but that would be hard since you'd have to move with on hand on the joystick, aim with another hand on the spinner, and fire with...  umm...
Anyway, you get the idea.
genesim
  • Last login:April 12, 2010, 08:18:42 pm
« Reply #3 on: October 23, 2007, 11:36:29 pm »
Happs Rotaries with a druin's board is what I use.   No replacement.
And yes, I use it on player one with great results.
Not only do I like it for that, but as a fighting stick and all around pair for the supers in dual arcade mode like Robotron, I have no regrets.
Check out my pics in the project department page 3....(shameless plug.  ;D)
On a side note, I used to get by with a spinner at extremely low settings and then use a Top fire...but that even sucked to.   Rotatries (non-optical for me) are the only way to get the authentic feel...plus you get two more programmable buttons(left twist, and right twist) for other purposes!
« Last Edit: October 23, 2007, 11:43:17 pm by genesim »
Avrus
  • Last login:September 07, 2011, 09:17:25 pm
  • Canada
    • The Avrus Arcade Project 'Conquest'
« Reply #4 on: October 24, 2007, 12:02:39 am »
If you didn't have a 12 way rotary, couldn't you theoretically map one button to rotate left and one to rotate right?  A big different but still workable, no?
______________________________
'Conquest' upright 4 player arcade project log:
http://avrus.blogspot.com/
genesim
« Reply #5 on: October 24, 2007, 12:58:19 am »
You know what, that is exactly what I did!
The spinner wasn't the way, but instead I used the left and right on the 8 way RIGHT back when I had the top fire on the right.
So I would use the left arcade stick for movement and the right for firing and the left rotate and right rotate.
Screw all that though...just get the rotatary..of course what to do with those U360's....can't have it all.  ;D
Thats why I always brag about my setup.   But the Ulimate 360's are always up in the air to replace my qbert stick.
Mr Wilson
  • Last login:August 14, 2018, 01:24:44 pm
  • it never ends!!!!
« Reply #6 on: October 25, 2007, 01:15:59 pm »
the same for midnight resistance i remember that had a clicky yellow joystick the same ikari warriors
Donkey_Kong
    • CNC Machines
« Reply #7 on: October 25, 2007, 02:00:45 pm »
I used to play this game at the "Circle K" convenience store up on the big hill on Carr st. in Arvada, CO. I was soo young I barely remember how that joystick worked. I remember the game was cool, but hard for me and I never made it far. I usually would have 1-2 quarters max, per visit.
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: October 25, 2007, 02:11:05 pm »
SNK LS-30 joysticks (Which I think were actually made by Seimitsu) are what the game originally used.  Happ mechanical rotaries are the current equivalent.  MAME has hacks to allow Happ Optical rotaries or pushbuttons to work with it, at the expense of some accuracy with the mechanical sticks, but we won't go there.
And one of the reasons it was so difficult is you had a limited number of shots before you had to find more ammo.
maxmix
  • Last login:September 27, 2016, 07:07:14 am
    • Phoneking.co.uk
« Reply #9 on: October 30, 2007, 06:25:18 pm »
Hi Guys
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=170159396783
I just bought 2 of these babes from the USA (I'm in Scotland, very hard to find)
For a future project I'll be starting later in the year....
maxmix
