Author Topic: Leaf switch assembly  (Read 1722 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: October 22, 2007, 11:51:24 pm »
Hi guy have just bought some leaf switches for my arcade machine and having only ever used cherry microswitches I am a bit clueless as to how to put them together. I have the button a plastic bracket with two metal sticks and a nut thing. please see pic. Can you guys help me with putting it together and how to wire up please
« Last Edit: October 23, 2007, 12:31:11 am by Marky_1979 »
whammoed
  • Last login:January 31, 2026, 10:01:01 pm
  • Crack don't smoke itself
    • NiceMite
Re: Leaf switch assembly
« Reply #1 on: October 23, 2007, 06:22:45 pm »
Marky_1979
    • Personal Webspace
« Reply #2 on: October 25, 2007, 04:19:19 am »
Thanks buddy cant see anything about the wiring on there though unless I missed it.
whammoed
    • NiceMite
« Reply #3 on: October 25, 2007, 08:11:52 am »
Just use 0.187 quick disconnects.  Ground wire to one leaf and signal wire to the other.  Should be easier than wiring a microswitch pushbutton since there are only two contacts and the microswitches generally have 3.
Marky_1979
    • Personal Webspace
« Reply #4 on: October 25, 2007, 02:33:58 pm »
Thats a good point Iv just bought the quick disconnects 1 final question and sorry if its an obvious answer but which one is ground?
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: October 25, 2007, 02:42:26 pm »
The one that isn't signal.   :laugh2: :laugh2: :laugh2:
It doesn't matter - the switch just sends current through when it's closed, either way you connect it or if you alternate around the panel will be fine.
