Author Topic: Led Wiz - a little help needed  (Read 6323 times)
diverdown
  • Last login:April 21, 2025, 03:45:48 am
« on: October 21, 2007, 07:46:54 am »
Loadman (if you read this), First of all the app you made for the led wiz is ace.
I didn’t even need to read any distructions…(he says even though he cant get it to work 100%)… I programmed my ledwiz and booted up mala and voila. Control panel looks sweet. I was wondering how I was going to inform the ledwiz of which controls to light up for which games
The little thing knew all by its self 
I now have one problem, which I cant solve searching BYOAC.
When I boot up the PC and boot straight to mala it gives me an error “LED_WIZ PLUGIN ERROR: Config file not located at :plugins\ledwiz.cfg”
I have the file located as c:\emulators\mala\plugins\ledwiz.cfg.
I also copied it to c:\emulators\mala\ledwiz.cfg
I also copied it to c:\ c:\emulators\mala\plugins\ledwiz\ledwiz.cfg
It still has the error. If I click ok and load up mala and then exit mala and then restart it manually then the ledwiz works.
What have I done wrong? :dizzy:
Diverdown
If it ain't broke give it to me...i'll soon fix that
edwardvci
  • Last login:February 23, 2009, 08:56:49 pm
  • Insert Coin.........!
Re: Led Wiz - a little help needed
« Reply #1 on: October 21, 2007, 03:40:54 pm »
Cant help. :dunno
But I do have the same problem after I upgraded to the newest version
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
« Reply #2 on: October 21, 2007, 08:04:56 pm »
diverdown,
how did you tell mala to launch at windows start up? through the mala config or through a shortcut?
can you try this:
- create a shortcut to c:\emulators\mala\mala.exe
- make sure the start-in directory is: c:\emulators\mala\
- once you create the shortcut, see if it works.
tell us what happens...
Might be the way mala is telling windows to launch on startup.
diverdown
« Reply #3 on: October 22, 2007, 12:18:54 am »
i will give that a go. I am using mala 8 as I have had some bugs with 9
i was using the "start with windows" check box. but will try the start menu shortcut.
loadman
  • Moderator
    • MaLa
« Reply #4 on: October 23, 2007, 07:53:24 pm »
Yeah...
There was an updated version (probably not on the mala website) that addressed to 'working directory' bug when launching straight into MaLa..
I will search for that post:
here it is:
Enjoy   :cheers:
http://forum.arcadecontrols.com/index.php?topic=64275.msg650356#msg650356
We must post a new version soon Edge   ;)
« Last Edit: October 23, 2007, 07:58:21 pm by loadman »
diverdown
« Reply #5 on: October 26, 2007, 05:36:04 am »
thanks
i used the shortcut and unchecked the start mala option and all is good
loadman
  • Moderator
    • MaLa
« Reply #6 on: October 26, 2007, 05:59:09 am »
Did you try the updated version of the plug-in that was attached to that post?
edge
« Reply #7 on: October 26, 2007, 08:41:16 am »
Loadman,
Does that mean I have to come out of retirement? ;-)
diverdown
« Reply #8 on: October 26, 2007, 08:41:42 am »
Not yet but i will..... Will this fix the screensaver/  attract mode not working in Ver8 issues too?
loadman
  • Moderator
    • MaLa
« Reply #9 on: October 26, 2007, 06:44:54 pm »
Loadman,
Only if it's fun you desire
diverdown
« Reply #10 on: October 27, 2007, 02:25:36 am »
now using the latest plugin file and the latest mala
- still no good.   It was working with mala 7 ot 8 (without the ledwiz)
also - should I have anything showing in the Hardware tab - i only have the ledwiz so I assume not.   The plugin shows and the leds light up properly.......  but i cant find any options to play leds at random during screen saver etc...
loadman
  • Moderator
    • MaLa
« Reply #11 on: October 27, 2007, 02:34:00 am »
I think there is a missunderstanding here.
1) This plug-in update is to fix the problem with the led-wiz plug-in not finding the ledwiz cfg file when you boot staright into mala on windows start...  Nothing to do with the screensaver.
2) Plug-In options (like the led-wiz) You need to run the Configuration program that is supplied with it. MaLa config does not have options for Plug-ins
edwardvci
« Reply #12 on: October 27, 2007, 01:43:57 pm »
Thanks that did  the trick / installed that patch and all is good
diverdown
« Reply #13 on: October 28, 2007, 03:44:35 am »
sorry.
the plugin update fixed the start not finding ledwiz issue thanks
now all I cant do is see images in screensaver.  The screen flashes at correct interval to be showing a snap file but the image does not actually show.
loadman
  • Moderator
    • MaLa
« Reply #14 on: October 28, 2007, 05:16:59 am »
have you tried this?....
http://forum.arcadecontrols.com/index.php?topic=71928.msg750693#msg750693
diverdown
« Reply #15 on: October 29, 2007, 03:55:25 am »
will do tonight, and will stop replying to this thread and just use that one, instead of both
ta
