Author Topic: resize mala layout  (Read 2738 times)
Mr Wilson
  • Last login:August 14, 2018, 01:24:44 pm
  • it never ends!!!!
resize mala layout
« on: October 19, 2007, 04:18:04 pm »
hi i would like to use game creature's blue layout but it appears to small on my screen i resized it in photoshop to (1280x1024) it starts the right size for about 2 secs then goes back to the old size is there anything i can try?
Thanks ;D
loadman
  • Moderator
    • MaLa
Re: resize mala layout
« Reply #1 on: October 19, 2007, 06:18:59 pm »
Thanks ;D
It's a Fixed size layout.  You need to edit it using the MaLa Layout Editor. It will be a bit of work to reposition / re-size some of the elemnts so it works propperly.
http://wiki.arcadecontrols.com/wiki/Mala_Layout
shock_
  • Last login:January 30, 2020, 06:23:29 pm
  • In Brisbane, it's GMT+10 all the time.
« Reply #2 on: October 22, 2007, 09:34:45 am »
Tell MaLa under the "display" tab to change your screen resolution to match the version of "Blue" you're running (hopefully 1024x768).  It'll stretch a bit since 1024x768 is 4:3 versus 1280x1024 at 5:4.
Are you using an LCD screen perhaps? If you are, your video driver might not scale up when you select a different resolution, and just give you a 4-sided letterboxing instead.  I hate that. Is that what's happening?
