Author Topic: Rounding Large Angle Joints  (Read 2600 times)
Dmod
  • Last login:July 12, 2012, 06:50:45 pm
« on: October 19, 2007, 01:05:13 pm »
I'm building a multi-sided box with angles larger than 90 degrees.  I'd like to round the edges of the box for a more finished look.
Is this possible using a router, or is there another way to do this besides sanding freehand?
My Projects:
Suspended Animation Scratch-built Cab
Driveshaft Arcade Seat Platform
Kaytrim
  • I'm too nice a guy
Re: Rounding Large Angle Joints
« Reply #1 on: October 19, 2007, 01:09:54 pm »
depends on how much past 90 you are talking about.  Normaly I'd use a belt sander the length of the edge and do it freehand.  I've posted these pics before but here they are again.  the before and after using a belt sander and 80 grit followed by a random orbit sander with 100, 120, 220 grits to smooth things out.  Make sure to use a respirator if you have MDF and don't do it in the house.
unclet
« Reply #2 on: October 19, 2007, 01:18:36 pm »
Kaytrim
Did you have multiple levels of MDF under there so you could sand off the pointed edge seam without exposing a gap between the MDF pieces after sanding?  I mean it seems like you could not just have started with two pieces of 3/4 MDF meeting together and then decided to sand off the leading edge .... since this would have left a gap showing after sanding was done .... correct?
It would nice to see a picture on the control panel without the side piece attached so I can get a better idea of what the MDF looked like underneath the top and front pieces.
Did this make any sense   :dunno ..... hard to explain.
« Last Edit: October 19, 2007, 01:20:22 pm by unclet »
Dmod
« Reply #3 on: October 19, 2007, 02:13:15 pm »
Thanks for the pics K.
unclet:  I think he just has the corner meeting at a miter joint so as long as the angles match on both ends, there wouldn't be a gap.
My Projects:
Kaytrim
« Reply #4 on: October 19, 2007, 03:16:06 pm »
Ask and you shall receive.  I have just those pics in my project announcement thread.
Link Here
TTFN
