Author Topic: Cabinet Power Switch connection question  (Read 1877 times)
unix4hire
  • Last login:October 16, 2008, 06:12:47 pm
  • activate interlocks...
    • My Business
« on: October 16, 2007, 11:12:27 pm »
Probably a simple question especially for experienced folks!
There is a switch on the top rear or my Ms Pac, a SPST switch I believe, with two unconnected wires hanging from it.  My question is, which of the 4 posts in the actual cabinet switch do I connect the two wires into so I can turn on/off the machine from the outside?  Thanks!
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
Re: Cabinet Power Switch connection question
« Reply #1 on: October 16, 2007, 11:58:07 pm »
Newb responce here: without knowing where the wires come from, and where they go to, I wouldn't even guess.  The photo isn't focusing on the switch.  I think that you really have a DPST switch (dual post, single throw).  I'd guess that it's A&B connecting to D&C.  My cab has the 12v and the 5v running to my switch.
SavannahLion
« Reply #2 on: October 17, 2007, 01:20:33 am »
That photo looks like an interlock switch. It's listed in the schematic as a DPST, but, based on what other people describe, it's physically more like a DP3T switch with some of the posts tied together. Push in and the system powers on. Pull out and the system powers on. Leave it in the "middle" and it's in an off state. From what I can tell on the schematic A/B DO NOT connect to C/D, that would be a direct short. One pole is between A & B and the other pole is between C & D. To put it simply, pop the switch and the continuity between A & B is broken. Same for C & D. The quality of my copy of the schematic is less than stellar, so it's probably best to take a multimeter and test this.
According to the schematic, it's wired in series. one brown lead goes to the AC plug, the other leads to wherever.
One blue lead leads up to the main switch which is a SPST wired in series. The other blue lead off to wherever.
In other words, according to the schematic, one of the blue leads should already be connected to the main switch. The other lead on the main switch leads off to the AC plug (with an inline fuse).
DO NOT depend on my information, the copy of the schematic I have isn't in the best quality, what with water marks and splotches all over it. I don't own a MS Pac much less any cabinet with this type of kill switch. I simply looked at the schematic as the OP should do as well.
« Last Edit: October 17, 2007, 09:55:37 am by SavannahLion »
unix4hire
    • My Business
« Reply #3 on: October 17, 2007, 02:41:43 pm »
Thanks for the replies.  The switch in the picture must be getting old because I cannot pull it out to keep it in an "on" state, it must always be depressed.  I'll trace the wires to see where they're going, especially if only 2 are really required to turn on the machine I wonder where the other two go?
SavannahLion
« Reply #4 on: October 17, 2007, 02:54:57 pm »
You have a basic momentary switch with no "cheat". Like what Happ sells.
....especially if only 2 are really required to turn on the machine I wonder where the other two go?
Um... that's not really how I meant to describe it. I suggest using a multimeter to check the circuit out. Then you can fully understand how the switch works.
« Last Edit: October 17, 2007, 02:57:47 pm by SavannahLion »
