Author Topic: localarcade.com Registration broken ?  (Read 4483 times)
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« on: October 16, 2007, 04:34:42 pm »
Hey there.
Im looking to get an account on localarcade.com  I have some artwork i want to upload / download in the unclean / non vector sections.
I cant seem to sign up... as the auth code is not working.  Who do i contact for this ?
WunderCade
Re: localarcade.com Registration broken ?
« Reply #1 on: October 16, 2007, 05:27:44 pm »
Not only that, when I DL the Ms. Pac .AI files from there, I only get a small quadrant of the artwork. Let me know if you have this problem too. You do not have to be registered to download the artwork.
Arm123
« Reply #2 on: October 16, 2007, 06:32:13 pm »
I am able to download and open the Ms Pacman ai files with no issue...  I am using AI CS2.
Can you download from the unclean section ?
zorg
« Reply #3 on: October 17, 2007, 02:12:28 am »
file is not BROKEN, it's just the document setting that is set incorectly.
open the file in illustrator and correct the document setting
I'm on the planning stage
Arm123
« Reply #4 on: October 18, 2007, 06:14:22 pm »
Anyone here a member of that board and is able to download from the unclean section ?
WunderCade
« Reply #5 on: October 18, 2007, 10:06:52 pm »
I am a member, even when I log in, The download buttons are not active. Are you having that problem as well?
zorg
« Reply #6 on: October 19, 2007, 04:12:23 am »
yes.
sirwoogie
  • Supreme Chancellor
  • Last login:April 23, 2025, 10:29:35 pm
  • It's Hollyfeld in a Winnebago!
« Reply #7 on: October 19, 2007, 10:44:48 pm »
Sorry about the login problems ya'll. I've corrected them. Please try again.
Arm123
« Reply #8 on: October 20, 2007, 11:34:24 am »
localarcade.com seems to be dead as of this posting.  I get 500 error code.
I some work is being done on it
WunderCade
« Reply #9 on: October 20, 2007, 11:48:30 am »
Same here. 500 Internal Server Error
sirwoogie
« Reply #10 on: October 20, 2007, 12:14:53 pm »
Good to go. Seems the php processors decided to just loose their minds.
Arm123
« Reply #11 on: October 20, 2007, 12:44:04 pm »
Its  back up...   However, i cant register.
I type in the pass code and it never works.  I think some of the code is cut off.
sirwoogie
« Reply #12 on: October 20, 2007, 12:46:51 pm »
Try now.
WunderCade
« Reply #13 on: October 20, 2007, 01:04:06 pm »
Everything works fine for me now. I can login. I can navigate. And all the DL buttons are now active. Thanks woogie.
Arm123
« Reply #14 on: October 20, 2007, 03:20:32 pm »
Finally able to register.
However, i logged in and still can not download from the unclean / non vector sections.
WunderCade
« Reply #15 on: October 20, 2007, 03:47:40 pm »
What do you need Arm?
Arm123
« Reply #16 on: October 20, 2007, 04:09:05 pm »
I dont really need anything.
I just see a few things i may want in the future and that i would like to download and trace.    :)
facesmiths
  • Last login:April 10, 2011, 07:53:05 pm
  • nemo goggles
    • Borg Steam Factory
« Reply #17 on: September 05, 2008, 02:30:28 am »
anyone have any idea if the site is down again? I have been trying to log on to look around and have not been able to for over a week
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #18 on: September 05, 2008, 08:55:42 am »
I can't connect either.
Zeno
  • Last login:May 12, 2009, 11:22:33 pm
  • Movement is an illusion
« Reply #19 on: September 05, 2008, 04:02:34 pm »
Ditto.
Have you tried http://vectorlib.free.fr/?
Zeno
Running: MAME
Projects: MK3, Ms. Pacman
zorg
« Reply #20 on: September 05, 2008, 05:19:58 pm »
Ditto.
this one is still maintained. :D
I take care of it :D
facesmiths
  • nemo goggles
« Reply #21 on: September 06, 2008, 05:26:41 am »
yes it is still there but but it is not complete. @ZORG are you going to host everything? I have some stuff you dont incase you want it and it is not possible to get from the localarcade.com site
oh yeah any interest in hosting corel vector files too. as soon as I get my new copy of corel draw I would be happy to send everything in that format your way
zorg
« Reply #22 on: September 06, 2008, 12:44:19 pm »
vectorlib will still dedicated to vector format files (pdf, eps, ai, svg, corel, etc) but  curently, (ie teasing inside) I'm not hosting bitmap files.
I have a backup of mostly everything on AAL but thanks I'll keep it in mind if it appears I misses some important ones.
regarding format, I'm currently working on cleaning files,  and exporting every one to various format, eg: illustrator, pdf and svg.
I guess you can imagine the work involved.
so feel free to provide any new vector material. use the email adress thats on every page.
shred5
  • Last login:July 25, 2013, 04:37:40 pm
« Reply #23 on: September 08, 2008, 11:31:30 am »
Yea I can not get on eithe rand I need some artwork.... someone else should host a site with all the stuff backed up or a mirror site incase it ever goes down and never comes back up..
Dave
sirwoogie
« Reply #24 on: September 12, 2008, 10:51:27 am »
Still maintained. Vacations, real life, and a server that is being a big snit is holding it up. I am working on it. :)
