Author Topic: What are those rings for that have wires wrapped around them?  (Read 1686 times)
Neverending Project
    • Arcade Fixer
« on: October 10, 2007, 03:53:26 pm »
The little rings that have wires wrapped through and around them. Are they for strain relief? Are they for removing interference? Are they magnetic? Most important, can I remove the one on the bundle of wires going to my monitor (CRT PC monitor) display control panel?
grantspain
Re: What are those rings for that have wires wrapped around them?
« Reply #1 on: October 10, 2007, 03:58:44 pm »
ferrite rings,to help prevent noise along signal lines i.e for preventing interference,i have removed some in the past without negative affect
its probably something to do those funny laws you have in the states over radio interference
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #2 on: October 10, 2007, 04:35:36 pm »
Yes Grant is 100% right, in this case it is reducing the noise created on the video leads of your Chun Yun (Albatron) PCTV, my guess is the board is a GP7738.
Why do you ask about the ferrite beads?
Rick Nieman
Rick@niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Neverending Project
    • Arcade Fixer
« Reply #3 on: October 10, 2007, 05:13:54 pm »
I am relocating the display control panel, and the ferrite ring won't fit through the hole I need it to. I can either remove the ring (and leave it off), or drill the hole out larger. I would prefer the former.
And thanks!
grantspain
« Reply #4 on: October 10, 2007, 05:39:53 pm »
you should able to remove the cable from the ring without damaging either,then you can test your monitor to see if this causes any negative affects
Ken Layton
  • Guru
  • Technician
« Reply #5 on: October 10, 2007, 06:17:04 pm »
Yes that ferrite ring is for reducing radio and television interferance. It's put there to comply withh FCC regulations in order for it to be sold in the USA.
Neverending Project
    • Arcade Fixer
« Reply #6 on: October 11, 2007, 11:34:11 am »
Thanks for the quick help! I removed the ring and saw no problems.
