Author Topic: 3" HighLip TB mounting plate doesn't fit  (Read 1193 times)
Lakersfan
  • Last login:May 03, 2025, 12:22:30 am
« on: October 09, 2007, 01:30:59 pm »
The title says it all... I ordered the following from DM and just got home to open my package. Everything was great, but as I was checking things out I noticed my zinc mounting plate does not fit around the lip of my HighLip TB - it sits on top the lip. Am I missing something or did I just order the wrong part?
Here's how my order looked when placed...
(1) Highlip 3" trackball (56-0100-11HL) w/ translucent blue TB
(1) TB mount (clear zinc) for above TB
Thanks guys!
Mike
EDIT- FYI, I looked at the mounting kit package and the product # is 55-1102-00 if that helps...
« Last Edit: October 09, 2007, 01:34:11 pm by Lakersfan »
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: 3" HighLip TB mounting plate doesn't fit
« Reply #1 on: October 09, 2007, 03:21:59 pm »
Are you sure you got the highlip model, and not the highball one.  Look the the top of the case:
Left is highlip, right is highball.  Highball lip is level with the wings.
The highball has a wider lip to allow the ball to sit higher, and needs a different mounting plate (55-1104-00).
Also make sure you have the right plate: the highlip plate should have a 3" hole.
Edit: just to make clear, the part numbers you posted should fit.  That's why I'm describing the parts.
« Last Edit: October 09, 2007, 03:23:54 pm by u_rebelscum »
Robin
Knowledge is Power
Lakersfan
« Reply #2 on: October 09, 2007, 05:11:57 pm »
I think you're right. My TB has wings and looks like the righthand picture. I'll contact DM.
Thanks rebel!
