Author Topic: Robotron Side art?  (Read 1567 times)
JesterDEV
  • Last login:November 25, 2010, 05:29:21 pm
  • OU812?
    • Jester's Temptation
Robotron Side art?
« on: May 04, 2003, 12:04:53 am »
Would anyone know of or have a image of this? I did find I stencil set, but its $125 and I just dont have the money. I have looked at a few but nothing that I can use..
btw, what the hell color are the sides? White? Silver? I am trying to replicate it with psp but having no luck what so ever.
« Last Edit: May 04, 2003, 12:39:54 am by JesterDEV »
Great big gobs of greasy grimey gopher guts.
JesterDEV
  • OU812?
Re:Robotron Side art?
« Reply #1 on: May 04, 2003, 11:59:58 am »
I managed to find a listing of the colors:
Sherman Williams Isle of Capri (blue)  SW1783
Sherman Williams  Theater Red  (red) SW1602
Sherman Williams Sliverado  (silver)  SW1005 - not exact, but as close as I could get.
Now to get them as close as I can in psp.
http://www.appolo.com/colorcodes/robotron_color_codes.htm
Ledbetter
  • Last login:March 01, 2005, 08:13:19 pm
« Reply #2 on: May 04, 2003, 12:10:49 pm »
 Its a silver color. Here is a site where someone did a complete side restore with the paint codes he used-
http://www.arcadefever.com/robotronproject.htm
 He has a nice side profile that you could blow up and trace if you want to make your own stencils. I used a similar picture of a Robotron mini to make stencils. I went the tracing paper route, but if your good with Adobe Illustrator you could use that instead. Its a pretty simple side art to copy, just a bunch of strait lines.
 Edit- Heh, I see you found the site on your own.
« Last Edit: May 04, 2003, 12:12:08 pm by Ledbetter »
GearHead
  • Last login:January 01, 2022, 11:24:59 am
  • need more gear...
« Reply #3 on: May 04, 2003, 01:56:13 pm »
This guy used the same paint colors but did a little tweaking on the silver...
http://www.tutankham.com/paints.htm
Robotron colors come from Appolo.com, I post them here because I have verified the color against a real restoration I have done and confirmed the match. With the silver specifically, the answer to get it right was to add a touch of black to the paint and then get some aluminum dust from an auto body shop. With those alterations, the paint is dead on.
