Author Topic: Vision Pro M# KT-2938f Sparking  (Read 2620 times)
TexasWalter
  • Last login:January 27, 2012, 04:59:11 pm
« on: October 06, 2007, 05:47:07 pm »
Inside the tube just as the monitor stars it will start sparking around where the flyback hooks up. I know it spent 1 - 2 hours in a light rain.
Could it have water in it?
If so what can be done about it?
grantspain
Re: Vision Pro M# KT-2938f Sparking
« Reply #1 on: October 06, 2007, 06:02:01 pm »
discharge the tube,remove the anode cap and clean the surround of the hole with a light cleaning fluid on sprayed on a paper towel(do not spray on to the tube),do the same with the anode cap and make sure everything is perfectly dry-make sure you blow out any debris in the hole as well then reconnect
TexasWalter
« Reply #2 on: October 06, 2007, 06:16:39 pm »
Holy crap dude thank you so much did just just what you said and BINGO all better.
 :notworthy:  :notworthy:  :cheers:
Next question where can I find info on it? I have looked on Happ no luck Google no luck? Any ideas?
bluevolume
  • Last login:July 22, 2019, 12:14:32 pm
  • I wish I'd bought more pins...
« Reply #3 on: October 06, 2007, 10:06:34 pm »
Its awesome that this question gets answered so quickly now.
Didn't used to be this easy.  :(
SABRECADE LIVES ON
grantspain
« Reply #4 on: October 07, 2007, 05:59:25 am »
i missed your first post regarding this subject,i am not sure why.
as for happ vision pro info,what info are you after-schematics?
TexasWalter
« Reply #5 on: October 07, 2007, 09:47:50 am »
Sorry I guess I should have made a new post for this question.
What I would like to find is info about the resolution and any other settings I may need to know about.
grantspain
« Reply #6 on: October 07, 2007, 10:59:05 am »
i am not familiar with vision pro monitors but from what i can find its a svga monitor 31khz,normally if your monitor has a vga d-plug then its normally 31khz
