Author Topic: GENS FE & GENS AVGA Released.  (Read 4057 times)
wboy
  • Last login:November 03, 2005, 05:09:19 pm
« on: May 03, 2003, 02:05:41 am »
GENS FE v2.11 (Release 2003-05-03)
Please note Gens FE is an unofficial release of Gens emulator.
The custom modifications made are intended to benefit those running front-end
software to launch various emulators on their converted pc/arcade cabinets.
The following custom modifications have been made in Gens FE:
 - Removed all [Ctrl] and/or [Shift] & [Alphanumeric A-Z, 0-9] keyboard
   shortcuts.
 - Remapped the render cycle backwards/forwards keyboard shortcuts [F11]/[F12]
   to [Ctrl] & [F11]/[F12].
 - [F11] toggles the frame rate display
 - [F12] takes a snapshot of the screen.
 - [Esc] will quit the Gens emulator.
 - [P]   will pause game play.
GENS AVGA v2.11 (Release 2003-05-03)
Please note Gens AVGA is an unofficial release of Gens emulator.
The custom modifications made are intended to benefit those who power their
converted pc/arcade cabinets with Ulitmarc's ArcadeVGA video card.
The following custom modifications have been made in Gens AVGA:
 - Custom ArcadeVGA resolutions 321x240 and 256x240 are used in full screen
   "Normal" render mode, allowing games to be run in their native resolution
   (non-interlaced).
   shortcuts.
Many thanks to Brentley_11 (and others that offered) of BYOAC for hosting the downloads.
Get them at http://gmr.no-ip.com/arcade/
Enjoy.
wee beastie
  • Last login:October 06, 2003, 03:33:02 pm
Re:GENS FE & GENS AVGA Released.
« Reply #1 on: May 03, 2003, 01:09:36 pm »
*click and save*
Much appreciated wonderboy!!!!  This will pretty much make my cab complete ;D ;D ;D
Thumpa
  • Last login:May 13, 2005, 08:51:34 pm
  • He who dies with the most roms wins!
« Reply #2 on: May 04, 2003, 07:05:22 am »
wow,it works great.
Maybe now i can finnally finish putting  my cabinet together instead of waiting for a way to run Genesis emulator!
Because u r so brainy....do u think its possible to modify zsnesw to run at 321x240 for those running a arcade cab with Arcadevga card?
the esc key modified version runs great but u still get that interlaced flicker
Thanks heaps for Gens AVGA
Thumpa
wboy
« Reply #3 on: May 04, 2003, 09:22:33 am »
wow,it works great.
Thumpa
May look at Zsnes sometime soon, but I give no promises or dates at this point of time.
I use SNES9X, as that allows me to set 256x240x16bit or any other ArcadeVGA available resolution.
Odonadon
  • Last login:January 27, 2006, 12:01:12 am
  • But then again, that's just one man's opinion.
    • Turbo2k
« Reply #4 on: June 16, 2003, 05:25:28 pm »
Hey, are these custom Gens compiles still hosted somewhere?  I'm not able to get through to the server and finally got off my lazy ass to download them today.
Odonadon
It's Captain Odonadon, and his magical bag of nuts.
« Reply #5 on: June 17, 2003, 05:27:08 am »
The link above still works for me...
Great builds BTW  ;D
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #6 on: June 17, 2003, 06:06:15 am »
Thanks heaps for this wonderboy!
Now I can put Gens on my cab and see what all the sega fuss is about.  I grew up on Nintendo and never played sega!
You wouldn't happen to have a modified version of VisualBoy Advance that allows you to exit with escape would you?
« Last Edit: June 17, 2003, 06:12:21 am by stuzza »
Odonadon
    • Turbo2k
« Reply #7 on: June 17, 2003, 11:29:21 am »
Great builds BTW  ;D
Oh sure.  TODAY it works.  ;)
Odonadon
Odonadon
    • Turbo2k
« Reply #8 on: June 17, 2003, 11:23:52 pm »
Great builds BTW  ;D
Odonadon
But tonight it doesn't.  Seems the GENS FE version zip file is either missing, or named wrong in the html main page.  The other two downloads work fine, but not the one I'm interested in :)  What luck!
Odonadon
Pyronious
  • Last login:June 04, 2021, 09:52:25 pm
  • Klatuu... Verata... Necktie.
    • Pyronious.com
« Reply #9 on: June 18, 2003, 03:01:43 am »
You can set this up using Girder if you don't want to wait for someone to do a built that quits with ESC.
On my system when VisualBoy Advance is started, Girder automatically presses ESC to eliminate the menu bar.  Pressing ESC again causes Girder to send an Alt-F4, which quits VisualBoy Advance.
I also use Girder to set relative volume levels for different emulators. For example, Gens is very loud compared to MAME, so when it is launched Girder automatically turns down the volume the correct amount. When Gens quits, the volume is reset to normal level.
Total automation is cool. Girder is your friend.
Odonadon
    • Turbo2k
« Reply #10 on: June 18, 2003, 11:52:33 pm »
I was finally able to download the FE version.  Whew.  Not sure what was going on last night.  Quite an ordeal to obtain something I should have a month ago :).  Now whats this I hear about MAME 0.68???   ;D
Odonadon
stuzza
    • ScreenshotArchive
« Reply #11 on: June 19, 2003, 02:17:27 am »
I've been looking at this Girder program and it seems quite complicated.  Do you have any example settings or saves i could use for this?
Odonadon
    • Turbo2k
« Reply #12 on: June 27, 2003, 12:33:17 am »
Okay, well, I've downloaded and installed Gens FE.  Yay.
Now, my problem is, it won't run.  I get a white screen.  That's it.  Absolutely nothing else happens.  I can alt-tab out of it, but no roms load.  Anyone have any idea?
Odonadon
wboy
« Reply #13 on: June 29, 2003, 08:09:06 am »
did u place the GensFE.exe in your existing gens directory?
shouldn't matter eitherway... just wanting to now...
Pyronious
    • Pyronious.com
« Reply #14 on: June 30, 2003, 05:16:19 pm »
See my message at:
http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=7940;start=msg58818#msg58818
For more info.
Odonadon
    • Turbo2k
« Reply #15 on: June 30, 2003, 06:22:22 pm »
Yup, Gensfe.exe is sitting right beside gens.exe :)  I might try reinstalled Gens alltogether, then throwing gensfe in with it again.
Odonadon
wboy
« Reply #16 on: July 01, 2003, 09:03:30 am »
hmmm... weird... as its only a keyboard remap, window title change and re-compile
just rename the gens.cfg file and run gens FE.  it'll rebuild the default cfg file for you.
My only guess would be that original gens.exe & cfg you have isn't 2.11???
Odonadon
    • Turbo2k
« Reply #17 on: July 02, 2003, 04:23:09 pm »
No idea.  I'll see if I can remember to check tonight :)  I've been more concerned with my busted TV in my cab :(
Odonadon
Isometric Bacon
  • Last login:February 28, 2014, 08:53:57 pm
  • Lets get dangerous!
« Reply #18 on: July 09, 2003, 11:07:14 pm »
Hey, the link seems to be down. Is there anywhere else I could obtain a version of GENSFE?
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
« Reply #19 on: July 09, 2003, 11:46:19 pm »
It's all about the Pentiums
Isometric Bacon
« Reply #20 on: July 09, 2003, 11:52:37 pm »
right here
www.geocities.com/jakejake28/pic.htm
Hmm, all I could find on that page was the ZSNES FE (which proved useful anyway :) thanks)
Whereabouts is the GENS FE?
jakejake28
« Reply #21 on: July 09, 2003, 11:55:59 pm »
check again, i see it
Isometric Bacon
« Reply #22 on: July 10, 2003, 12:02:35 am »
Ahh, it's there now :)
Many thanks.
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #23 on: July 10, 2003, 08:48:01 am »
Does someone have a working link to the GENS AVGA version?
Frostillicus
  • Arcade Artist
« Reply #24 on: July 12, 2003, 09:50:48 am »
(ok I try never to do this but...) BUMP!
anyone? Bueller? Bueller?
