Author Topic: cap kits  (Read 3083 times)
hellokitty69
  • Last login:October 01, 2007, 04:47:53 pm
cap kits
« on: October 01, 2007, 02:16:58 pm »
on an average, how often do you need to change out your caps?  me and my roommate just picked up a 2005 golden tee and I'm pretty sure the color has faded much past its original color.  id hate to go through the trouble of replacing the caps if it is not necessary.
i have a second issue while i have your attention.  every once in a while the screen gets very distorted and wavy.  a good smack on the side of the cabinet seems to be the medicine it needs.  is this a cap issue or perhaps a loose connection?
all input is appreciated, thanks
grantspain
Re: cap kits
« Reply #1 on: October 01, 2007, 03:07:37 pm »
it depends on the quality of the capacitor and the type of chassis
some monitors like hantarex suffered much from cap problems,this was mainly down to the quality of the caps and the fact that a lot of caps were near heat sources
in my personal opinion any monitor over 5 years is ready for a few new caps but in your case i believe you have nothing more than some bad solder joints and adjustment issues
hellokitty69
Re: cap kits
« Reply #2 on: October 01, 2007, 04:46:28 pm »
ok ill check the soldering tonight.  thanks
SirPeale
  • Green Mountain Man
Re: cap kits
« Reply #3 on: October 01, 2007, 04:54:16 pm »
You didn't happen to mention the monitor that's in there.  For all you know it's something that had been kicking around for a few years before being put in as a replacement.  It could have been run ragged in a really hot place.
Especially if it's a 7400/7500 series from WG.
grantspain
Re: cap kits
« Reply #4 on: October 01, 2007, 05:08:23 pm »
judging by your username you are based in the u.k,therefore your golden tee fore 2005 will be built by electrocoin in cardiff and it will have a hantarex polo 2 auto monitor
if you are from the states ignore me :dizzy:
SirPeale
Re: cap kits
« Reply #5 on: October 01, 2007, 05:52:54 pm »
Pretty sure he's in the US based on his email address.  Hello Kitty isn't just a European thing!
Level42
Re: cap kits
« Reply #6 on: October 01, 2007, 06:01:31 pm »
Think color problems are rarely caused by cabs. Try some pot adjustment, worked miracles on some of my monitors...
That other problems sounds like loose connectors or bad solderings. Don't bang, it will make it worse....
grantspain
Re: cap kits
« Reply #7 on: October 01, 2007, 06:02:32 pm »
just ignore me then,most people do :cry:
BobA
  • What Me Worry?
Re: cap kits
« Reply #8 on: October 01, 2007, 08:18:34 pm »
If it is a GT 2005 cab then it seems a bit early for a cap kit.  That is only a couple of years old.  Definately try some adjustments first.
SirPeale
Re: cap kits
« Reply #9 on: October 01, 2007, 11:16:06 pm »
Again, the cab may only be a couple years old, but the monitor could have come from anywhere.  When I was working street service, you bet your buttons if there was a problem with something on the street it got replaced with something we had in the shop.
bluevolume
  • Last login:July 22, 2019, 12:14:32 pm
  • I wish I'd bought more pins...
Re: cap kits
« Reply #10 on: October 02, 2007, 09:15:44 am »
This is correct, and common with Golden Tee in particular.  These cabs are seen mainly in bars, where they get a lot of abuse.  Also, with the series being updated almost every 2 years, there are a lot of conversions out there.  (Short lifecycle equals high frequency of conversions.)
SABRECADE LIVES ON
