Author Topic: MAME Compiler 64 v2.0.197  (Read 596313 times)
Yardley
  • Last login:July 22, 2025, 11:36:15 pm
Re: Mame Compiler 64 v2.0.197
« Reply #880 on: November 15, 2021, 09:09:01 pm »
Thank you!
Yardley
« Reply #881 on: November 15, 2021, 09:43:18 pm »
I was hoping this latest version would work but no dice. Does this utility still work for anyone for the latest version of MAME 0.237? I'm getting this error.
  • Last login:Today at 01:20:31 am
« Reply #882 on: November 15, 2021, 10:44:17 pm »
Thank you!
Glad to assist.   :cheers:
If anyone needs an older version, check for an Internet Wayback Machine backup between that version's release date and the next version's release date.
Latest backup of Headkaze's Mame Compiler 64 page to check release dates . . .
https://web.archive.org/web/20200812223145/http://www.headsoft.com.au/index.php?category=mame&page=mc64
. . . then go to https://web.archive.org/ and plug http://www.headsoft.com.au/index.php?category=mame&page=mc64 into the search field.
- There are over 100 backups between 13 Oct 2009 and 12 Aug 2020.   ;D
- The download link for that date's version is at the bottom of the MC64 page backup.
- Protip: "Blue dot" links are better than the "green dot" links.
MC64 and MAME release version numbers appear to have been synced since MC v2.0.161 and MAME 0.161.
MAME 0.197 was released on 25 Apr 2018 so MC64 v2.0.197 probably came out around 3.5 years ago.
https://docs.mamedev.org/initialsetup/compilingmame.html
To compile MAME, you need a C++17 compiler and runtime library. We support building with GCC version 7.2 or later and clang version 6 or later. MAME should run with GNU libstdc++ version 7.2 or later.
https://www.mamedev.org/?p=487
Starting with the December 2020 development cycle (after the anticipated release of MAME 0.227), we will switch to compiling MAME as C++17.
Bottom line:  MC64 v2.0.197 probably works with MAME 0.197 thru MAME 0.227, but anything newer is definitely out.
« Last Edit: November 15, 2021, 10:49:16 pm by PL1 »
Yardley
« Reply #883 on: November 17, 2021, 09:28:05 am »
Bummer, thanks for clearing that up.
mean62
  • Last login:July 20, 2024, 01:08:03 am
Re: MAME Compiler 64 v2.0.197
« Reply #884 on: July 20, 2024, 01:05:34 am »
Hello.  I've been trying for days to compile Mame 0.155.  I was able to compile 0.183 version, but want to go back to .155.  The patch files seem to work, but whenever I try to compile it I get the folllowing errors.  I've tried muliple versions of MC64, as well as multiple MinGW installs.  Any help would be appreciated.  I
Havok
  • Trade Count: (+17)
« Reply #885 on: January 30, 2025, 09:29:44 pm »
GUIs are lame. Here's some reading material for you:
https://mrdo.mameworld.info/compile.php
