Author Topic: Act Labs, Fire button flashes/moves crosshairs, but does not fire..Help  (Read 1606 times)
keithj202
  • Last login:September 27, 2007, 07:03:51 pm
Just got the Act Labs USb guns for Arcade.  Using Mame32.  Put button 1 as trigger.  Calibrated them,  When I fire at the screen, it flashes and moves the crosshairs to the right spot.  But does not register a fire.  Any help.  Going crazy.
Thanks,
Keith
BobA
  • What Me Worry?
Re: Act Labs, Fire button flashes/moves crosshairs, but does not fire..Help
« Reply #1 on: September 27, 2007, 09:04:07 am »
For mame32 have you set default game options/controller/enable lightgun input  and controller/mapping/lightgun device/lightgun?
ARTIFACT
« Reply #2 on: September 27, 2007, 02:35:49 pm »
same problem here
regular mame
mame.ini contains:
lightgun_device lightgun
lightgun 1
heeeeelllpp...
(it works PERFECTLY with the Model2 emu...)
« Last Edit: September 27, 2007, 02:37:47 pm by ARTIFACT »
keithj202
« Reply #3 on: September 27, 2007, 02:47:27 pm »
For some reason Mame32 will not let me highlight "Enable Lightgun Input".  Or Duel Light Guns.  But in Controller mapping I have lightgun selected for light gun device.  Any help with this.  Thanls.
Keith
ahofle
    • Arcade Ambience Project
keithj202
« Reply #5 on: September 27, 2007, 07:03:51 pm »
I got the gun to register a hit.  I don't know how.  But now it won't reload with the second button.  I have mapped both the trigger and reload button to button 1.  It just won't reload.  Any more help?
Keith
ARTIFACT
M37R01D
  • Last login:April 25, 2009, 06:23:25 pm
    • M37R01Dz M0Dz
« Reply #7 on: September 28, 2007, 01:08:26 am »
when selecting p1 button
you need to point the gun at the screen and fire,
in options you may also want to check, offscreen reload, or in cmd, -offscreen_reload
also you may wanna check here
http://www.act-labs.com/products/Act%20Labs%20Light%20Guns%20on%20XP.htm
codeena
  • Last login:December 03, 2023, 06:23:54 pm
  • This site is cool
« Reply #8 on: September 28, 2007, 03:47:27 pm »
Hey keithj202,
I did the following: check the "use the mouse" option in the game's properties. When in game, for Player 1's button 1, press ENTER to change and press ESC to clear any current assignments. Press enter again and pull your trigger (making sure not to move your gun to register any X/Y axes--I pulled the trigger while resting the gun on the glass). If it registers an axis, repeat the above. It should one have a single assignment (I think something like MOUSE B0).
On a simliar subject: If you're using only one Act Labs gun, as I am, I experienced an issue where both the blue and red (P2) crosshairs moved together to the same spot. I figured out how to remedy that issue as well.
Good luck!
ARTIFACT
« Reply #9 on: September 28, 2007, 05:06:26 pm »
ok i didnt point at the screen when registering... i wil try that tonight
thanks!
ARTIFACT
« Reply #10 on: September 29, 2007, 05:17:12 pm »
that worked!
M37R01D
    • M37R01Dz M0Dz
« Reply #11 on: September 29, 2007, 07:02:25 pm »
nice
i had the same problem, what happens is when you dont shoot on screen it registers as an offscreen shot, or reload
they were a pain to setup to the T
but after about 3 days of config i think i finnally have them all figured out
Model2 was great as it auto picked them up with no config needed
« Last Edit: September 29, 2007, 07:04:28 pm by M37R01D »
