Author Topic: Can I simply swap hard drives?  (Read 8877 times)
More Cowbell
  • That's just dumb!
« on: September 24, 2007, 10:28:34 am »
I have a computer in my MAME cab running at 1ghz currently. I bought a 1.7ghz computer and want to upgrade to that. Can I simply swap the hard drives or will this confuse the system? I don't want to start from scratch in copying files and configuring. I also have a video card that allows me to use s-video. Can that simply be swapped to the other system too? In my mind this would all work. Is my mind a good resource for information though? Not always.
I've got a fever...
Teebor
  • Last login:June 04, 2009, 12:39:06 pm
  • What does this button do??
Re: Can I simply swap hard drives?
« Reply #1 on: September 24, 2007, 10:34:10 am »
What operating system please?
XP- Give it a go, often works out ok. but can be fixed by re-installing over the top usually so settings are kept intact
DOS - should be fine
Vista - Never done it myself but I wouldn't bet on it :D
How was your french toast dear?
Smelly and ungrateful
-American Dad
TOK
  • The Game Always Wins
« Reply #2 on: September 24, 2007, 10:52:17 am »
I've always done a format and install on a new machine. The thing that might cause you the most trouble are the things built into the motherboard, like if your current system has an NForce chipset and you're installing on a motherboard with something else. It might just detect the new IDE controller and start using it, or it could just totally freak out and won't see the hard drive.
If I was going to try it, I think I'd probably going into Device Manager before the last time I shut down and uninstall all the motherboard related stuff so that they are hopefully just re-detected when you fire up the new machine.
« Reply #3 on: September 24, 2007, 10:53:51 am »
odds are, it won't work.
You'll want to reformat.
Ed_McCarron
« Reply #4 on: September 24, 2007, 10:59:50 am »
Often?  Unless the mobo has the same exact chipset, XP will crash upon boot.  Real PITA.  Don't think I've seen this work once without requiring a fresh install.
Please tell me I'm missing some simple step that makes life easier?
XyloSesame
  • Last login:September 17, 2024, 05:57:04 pm
  • the creepy prince guy...
    • The Nightingale Theater
« Reply #5 on: September 24, 2007, 11:05:01 am »
Oy, this sounds like a nightmare.
Install fresh on the new machine and use the old drive as additional data storage. Keep the OS on it's own drive. If you UG later, you should be able to install MAME and point it to the existing ROMS on your Data drive.
RE video, if you have the drivers, you should be able to install it in a new box - that's not to say it will work plug-and-play-like, but it should be do-able.
acro-ii
  • Last login:December 02, 2016, 12:12:22 pm
« Reply #6 on: September 24, 2007, 11:06:44 am »
You are.
Boot from XP CD with same service pack revision as is on your machine.
Go past the setup option to repair using recovery console.
It scans for the current os.
Then you get a repair option.
It works perfectly.  That's how I fix 90% of the pcs that poeple bring into my office.
XyloSesame
« Reply #7 on: September 24, 2007, 11:09:34 am »
You are.
Hey, Acro, does this leave the registry and installed programs intact?
acro-ii
« Reply #8 on: September 24, 2007, 11:11:08 am »
100% yes!
xmenxmen
  • Last login:September 16, 2012, 03:05:35 pm
« Reply #9 on: September 24, 2007, 11:19:48 am »
I have found computer advise here seems to be very limited....
As long as these system are all running ide drive and not raid controller of some sort, there's really no problem in porting it from one system to another.  Worst case is that you will have to update all the drivers once the system comes up.  I have done this so many time, it's not even funny anymore.
And in those case where you actually have a non support (by default xp) hard drive controller , then all you need is put the xp cd in there and have it added the drivers during the initial boot (F6), then perform a repair of the os.
Again, the basic home system is not that complex, so swapping between system and getting them to work is pretty much guarantee in xp with very low failure rate.
I say give it a go.
And if you do prefer to install fresh, all you have to do afterward is transfer your mame configuration to the same drive and directory layout and you should be up and running with minimal re-config.
XyloSesame
« Reply #10 on: September 24, 2007, 11:26:14 am »
I'm still dubious, but I always start with a fresh install, so I'm not the expert...
Question: Since XP will just be installing controller and bus drivers, does it matter if you use an OEM CD even if you're running a service packed OS?
Ed_McCarron
« Reply #11 on: September 24, 2007, 11:29:14 am »
You are.
Live and learn.  I'll give it a shot.  Thanks!
knave
  • Last login:October 15, 2025, 04:12:19 pm
« Reply #12 on: September 24, 2007, 11:49:14 am »
One added step that might help...
Make sure you change to the default VGA video card drivers before you swap.
This will make your install of the new GPU easier and possibly avaid any headaches.
-now just a bit of opinion-
While this can work, I always want my pc's to be squeeky clean.
I reccomend installing XP fresh and adding your old HD as a slave to copy your files.
For mame you should get all your configuration settings.
Either way do yourseld a favor and change the VGA driver whenever you change Video cards.
Oh and I know PC gamer did a walkthrough on how to do this in XP so I'm sure there are other guides out there.  Do a little Google-fu and you should find out all the steps needed to totally swap out your hd without a new install.
Good luck
xmenxmen
« Reply #13 on: September 24, 2007, 11:52:14 am »
In most case no.  Typically once you get the system up and running, you will go and update the drivers anyway.
Only case I seen it matter the most is when you try to do a repair on the system.  What happens here is the repair process will actually go out and delete the system files that's install in the windows directory and reload it from the cd.  The problem here is that there's files/drivers from other area that are still at the higher service pack.  They tend to conflict sometimes and cost the system to become unstable.  If the system does come up and you are able to re-apply the service pack, it normally does take care of the problem.
To avoid this completely I do recommend one to slipstream the service pack into the I386 directory or cd.  Just do a google search on slipstream xp if you need more details.
More Cowbell
  • That's just dumb!
« Reply #14 on: September 24, 2007, 12:04:43 pm »
Thanks for the advice. I'm running Windows 2000 on both systems. Does that make a difference to the XP-releated suggestions? I'm thinking that adding the hard drive as a slave and copying everything will be the most bomb-out proof way of going.
I've got a fever...
XyloSesame
« Reply #15 on: September 24, 2007, 12:06:21 pm »
However, your advice and Acro's advice both point to performing a repair from an XP CD. If you don't have a slipstreamed disc, you risk the conflicts and instability as stated above. Correct?
« Reply #16 on: September 24, 2007, 12:08:09 pm »
I've done plenty of installs and new machine upgrades. I don't have much luck installing a pre-installed OS on another machine. I wouldn't even mess with it if you value your time.
Setup a new machine properly and then copy over the files you want.
XyloSesame
« Reply #17 on: September 24, 2007, 12:09:37 pm »
Well said.
More Cowbell
  • That's just dumb!
« Reply #18 on: September 24, 2007, 12:22:44 pm »
Time was what I was really trying to save so if this is going to be more headache than time saver, I say to hell with it. Copy and paste, here I come. Glad I didn't just try plugging things in and switching things on.
I've got a fever...
« Reply #19 on: September 24, 2007, 12:24:06 pm »
Which of your dozens of arcade games is this?
FunWithFire
  • Last login:July 07, 2009, 01:17:30 am
« Reply #20 on: September 24, 2007, 12:31:42 pm »
Couldn't you just put your old HD in the new machine as a slave drive?
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #21 on: September 24, 2007, 12:32:02 pm »
I must be doing it wrong, I never have found a HDD swap funny  :dunno
Jouster
  • Flap, Flap...Crash
« Reply #22 on: September 24, 2007, 12:36:35 pm »
Make backups first of whatever you want to keep...just in case.
I would doubt that you could simply plug a HD into another system...especially one that is completely different...and have it work right off the bat as the main drive...secondary or data drive, sure.  The HALs wouldn't match and most likely you'll get a BSOD (Blue Screen Of Death).
If the systems are close in setup, it might work...either use the repair console method...or just fresh install it.
Jouster
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
« Reply #23 on: September 24, 2007, 12:53:00 pm »
You are.
This is not currently working, once you finish the repair you can no longer install windows updates. Have you done a repair in the past month? I've seen about seven fail.
boykster
  • The cake is a lie!
« Reply #24 on: September 24, 2007, 12:54:17 pm »
backup whatever you want to not lose....swap the drive and go directly to the recovery console (make sure to have an XP disc handy)
from the recovery console (assuming C is boot drive and D is cd drive with xp cd in it)
copy D:\i386\hal.dl_ c:\windows\system32\hal.dll
copy D:\i386\ntoskrnl.ex_ c:\windows\system32\ntoskrnl.exe
reboot.  Drivers and other stuff will be re-setup and you <should> be good to go.
Always backup data first though.....
Green Giant
« Reply #25 on: September 24, 2007, 01:35:08 pm »
Don't know if I got here to late, but I have never had trouble with this.  I have cleaned up friends computers in the past that had been so infected with viruses that they wouldn't run at all.  I dropped their harddrives in my machines, much faster and capable of running with all the other junk running, and ran some stuff to clean it up.
I find you just wait a little while and windows will recognize just about everything.  After I fixed their harddrives I just dropped it back in their machine, no problem.  The only thing I could possibly see going wrong is if you have several game controllers hooked up getting reassigned different device id's.  This isn't the darkages of computers, XP won't freak out and blue screen if it finds all new hardware.
Worst comes to worst, you will have the XP file system corrupted and have to install on a new harddrive.  Once the new OS is on there you can still add the old harddrive in the system as a backup and copy the files over that way.  I have also done that a million times on many machines.
Toxic Arcade, my first build
MrMojoZ
« Reply #26 on: September 24, 2007, 02:01:38 pm »
Thats not how it works nor does it reflect the issue being discussed. You lucked out in that your IDE controllers were close enough to not cause a problem. What happens when most drives are swapped between motherboards is XP will blue screen on boot, there is no hardware recognizing period. We used to fix with a windows repair but that has not been working, going to try Boykster's method next time I see a system that needs it.
Green Giant
« Reply #27 on: September 24, 2007, 02:12:30 pm »
I have done this 8 or 9 times all with motherboards built in the last few years with success on them all.  On servers this actually works even better as I have done this hundreds of times with many different operating systems on several types of servers.  Suse has many problems but Windows always worked great.  That is why I said in the past it would have caused problems.  The biggest problems I found was the video driver not getting recognized immediatley, but with some luck, windows will find something suitable and install it for you.
As for the issue being discussed, that covers it exactly.  He wants to just swap out the drives without doing any time consuming work.  This method should first be done using the vga video, but once up and running it should be able to install the correct drivers and use svideo.  And if it doesn't work, all of the information will not be lost.  As long as the bare minimum of hardware, keyboard mouse and monitor, is plugged in when booting the new computer, it should work.
« Reply #28 on: September 24, 2007, 02:21:59 pm »
On Windows Servers this is just about the worst thing you can do. Seeing as how many servers require you to install the controller during setup and windows won't have the drivers native. This is when you need a floppy... and ONLY A FLOPPY (goofy crap).
In the past we didn't have plug and pray and this wasn't an issue at all.
it should work.
Famous last words.
I'm glad you got everything to work Green Giant. I'm not calling you a liar, just saying my experience has been different. Completely different.
« Last Edit: September 24, 2007, 02:33:09 pm by leapinlew »
MrMojoZ
« Reply #29 on: September 24, 2007, 02:24:24 pm »
And I've done it hundreds of times with Windows XP, we are not discussing other operating systems. IT DOES NOT ALWAYS WORK. The other posters in this thread can back that up.
xmenxmen
« Reply #30 on: September 24, 2007, 02:32:51 pm »
This is so true.  Either everyone on here are quite in experience to this stuff or just have crappy luck.
And to the one mentioning HAL, if you look at his system, you can see that he's going from a 1ghz to a 1.7ghz, both are single cpu and either one has more than one core, so HAL is not a problem!
« Reply #31 on: September 24, 2007, 02:34:18 pm »
Why don't you tell me what you think HAL means, and then I'll tell you what it really means.
« Reply #32 on: September 24, 2007, 02:36:33 pm »
Man...
that damn cowbell really knows how to get a nerd fight started.
MrMojoZ
« Reply #33 on: September 24, 2007, 02:40:02 pm »
[quote author=xmenxmen link=topic=71670.msg736481#msg736481
[/quote]
No it isn't true. I can predict the out come of motherboard swaps between SiS, Via, Intel and Nvidia chipset matings. Can you?
Inexpirienced.  :laugh2: I have to do motherboard swap outs everyday (thank e-machines).
  • Last login:February 28, 2026, 04:55:22 pm
« Reply #34 on: September 24, 2007, 02:50:22 pm »
Isn't HAL the computer on 2001: A Space Oddessy?   ???
MrMojoZ
« Reply #35 on: September 24, 2007, 02:58:27 pm »
I'd say you were closer to the truth than xmenxmen.  ;)
gonzo90017
« Reply #36 on: September 24, 2007, 04:11:18 pm »
In my experience swapping hard drives rarely works. Only when the motherboards have the same chipsets has it worked. In my earlier computing days when I tried swapping them with different chipsets I have gotten the blue screen. But i've never tried it using his method so I can't say if it doesn't work.
Hey Green Giant why not just install your friends drives as slaves and clean them that way instead?
More Cowbell
  • That's just dumb!
« Reply #37 on: September 24, 2007, 04:26:21 pm »
Man...
Yes, my plan is working perfectly. Next thread... Kirk or Picard. Let's get ready to rumblllllllllllllllle!
This is for my original, scratch-built MAME cab, Lew. The other ones are running the classics so they don't need much power.
I've got a fever...
xmenxmen
« Reply #38 on: September 24, 2007, 05:36:58 pm »
Did u do one today?????????
Green Giant
« Reply #39 on: September 24, 2007, 05:52:55 pm »
That only works when I am trying to save their files.  This is my prefered method, but when you have 200GB of material, you need a big disk to handle the transfer.  Swapping out the harddrive in the new computer will only take a few minutes, and if it doesn't boot up, no problem, everything will still be there.  The biggest concern is setting up the video, if the video card remains the same, not using onboard, plug and play may very well recognize it.
Windows Server OS is the best at recognizing new hardware and new drivers without using the floppy.  Other OS's have trouble sometimes.  Typically the most important systems will be transferred including video, keyboard, and mouse on servers.  I worked for HP on servers for two years and we did this stuff constantly.  After several servers you can get some slowdown, but once or twice never has problems.  The only time you will need the drivers are for the onboard lan which typically never shows up.
And in the few times it wants the floppy, you can just virtually connect a floppy through the network and upload the driver directly without an actual floppy drive.
Oh, and Picard.
Everybody is so testy today, I never said you are all liars, I just said I have had success swapping out harddrives into completely different computers.  The original question asked if it could work to save him time, I think it can.
« Last Edit: September 24, 2007, 05:58:53 pm by Green Giant »
