Author Topic: Can i copy a Gauntlet Legends Hard drive  (Read 11185 times)
PileDriver
  • Last login:May 28, 2025, 08:53:44 am
  • I want to built my own arcade!
« on: September 19, 2007, 05:50:15 pm »
Recently the hard drive in my gauntlet machine started "knocking' during game play.
The internal self test shows it has no file system problems.
I'd like to copy it to a new drive before all is lost. Windows doesn't recognize it.
Drive Copy won't copy it. Any ideas?
PileDriver
Space Fractal
  • Space Fractal
    • Space Fractal
Re: Can i copy a Gauntlet Legends Hard drive
« Reply #1 on: September 19, 2007, 06:30:01 pm »
If Windows cant see the drive anymore. You might try to use one of the shareware file recovery applications like these:
www.R-STUDIO.com
www.quetek.com
www.file-recovery.net
Even the NTFS drive is gone, these application scae the whole drive for files, which can take long time. Then it need to copy it to a another drive (to aviod data loss). You might need to move the file damages HD to a another machine before trying recovery it.
 But Im actuelly not recommered to move windows system files, but instead  reinstall Windows XP. Data and FE files is the highest priotity to moved over first.
I do not have seen any good freeware applications, so you need to buying one first. I have simular trouble last year, but was not in my mame machine.
PileDriver
« Reply #2 on: September 19, 2007, 06:35:58 pm »
Thanks for the reply.
Just to make it clear.
It's from a real Gaultlet Legends cab.
I attached it to a win XP Pro machine to try to make a copy.
« Last Edit: September 19, 2007, 06:43:04 pm by PileDriver »
Q*Bert_OP
  • Oh yes, we did!
« Reply #3 on: September 19, 2007, 06:43:01 pm »
FYI, you need a hard drive copying machine to copy it...
Arcade hard drives are written as unpartitioned drives!
PileDriver
« Reply #4 on: September 19, 2007, 06:45:53 pm »
That's what I was afraid of.
I guess its off to find another drive.
Thanks,
PileDriver
AaronGiles
  • Last login:May 17, 2008, 09:59:11 pm
    • Aaron's Home Page
« Reply #5 on: September 19, 2007, 06:53:15 pm »
chdman.exe built with MAME can do it.
First, plug in your hard drive and identify which device Windows thinks it is (drive 0 will be your boot disk). Once you know the drive index, run
chdman -createhd \\.\physicaldriveX c:\gauntlet.chd
(where the 'X' above is replaced with the drive index, e.g., \\.\physicaldrive2 means the 3rd disk in the system). This will create a compressed copy of the hard drive on your c: drive. Then buy a new disk, plug it in, and extract the CHD file to it:
chdman -extract c:\gauntlet.chd \\.\physicaldriveX
Be careful with this last command as it will overwrite whatever hard disk you specify with the contents of gauntlet.chd.
Q*Bert_OP
  • Oh yes, we did!
« Reply #6 on: September 19, 2007, 06:54:13 pm »
If you only need to copy one drive, you're better off just buying the drive...
I happen to make many drives for a local amusement company, so buying a copier was a good investment for me...the one I got costs about as much as a new PC...
Drews Arcade
  • Last login:July 28, 2018, 01:15:02 am
« Reply #7 on: September 19, 2007, 07:00:44 pm »
Lots of software out there that will copy it, but its easy for me to replace them when there this cheep.
eBay Link
« Last Edit: October 11, 2007, 07:26:10 am by Peale »
PileDriver
« Reply #8 on: September 19, 2007, 07:08:38 pm »
Thanks for the link.
I'm going to get one and try to copy the old one.
Thanks for the info Aaron, I'll try it with the legends and if it works I'll make a backup of my Dark Legacy drive too.
I Love this Place!!!!!!
« Last Edit: October 11, 2007, 07:34:21 am by Peale »
PileDriver
« Reply #9 on: September 19, 2007, 09:10:47 pm »
I Just wanted to say thanks again.  :cheers:
I backed up to a CHD and extracted to another Hdd
and everything works great!
@Aaron  :notworthy: - The newest version of chdman (v119)wouldn't extract to the disk.
It allways errors with the following "error opening output file '\\.\physicaldiskX' "
I used v.83 and it worked fine. Just thought you should know.
tommy
« Reply #10 on: September 20, 2007, 12:42:51 am »
Excellent looking cab btw.
Havok
  • Trade Count: (+17)
« Reply #11 on: September 20, 2007, 08:04:32 am »
Did you use the same version to backup and extract?
PileDriver
« Reply #12 on: September 20, 2007, 11:41:50 am »
Yes.
Thanks, I've had it for about 2 years.
I can swap in the Dark Legacy board and drive and be playing in minutes.
Definitely one of my favorites!
  • Last login:July 23, 2025, 07:04:20 pm
« Reply #13 on: September 20, 2007, 11:53:57 am »
That massive marquee is just begging to be replaced by an LCD...  if that were a MAME cab.   :cheers:
tommy
« Reply #14 on: September 25, 2007, 10:42:24 am »
I was messing with Gauntlet Dark Legacy in mame and it seems to work perfectly but only at about 30% speed on my rig. I would imagine a dual core setup would have enough horsepower to make it run well. Try it in mame if anything happens to your hard drive and if you have a decent PC. It looks great too.
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #15 on: September 30, 2007, 12:01:42 am »
http://www.vendoramusements.com/hard_drives.htm
http://www.revisionx.com/kiproject/ki1.html
Use these links as a reference.  I have a KI machine that was/is/has a bad/broken HD.
kjoel0123
  • Last login:January 07, 2012, 09:57:19 am
  • Cabs for sale - Please see my flickr page for all
« Reply #16 on: October 01, 2007, 01:40:54 pm »
I own the original cab gauntlet dark legacy and I can tell you that the graphics are top notch. Its one of my favorite cabs. I love it. Try to get the cab you wont be dissapointed ! I traded a mini cab for mine.
Dedicated Cabaret cabs I currently own:
Neo Geo/ GT Complete/Mspac galaga reunion
full size cabs: Playchoice 10 Single Monitor/Nicktoons Racing/Junior King Cocktail/ Super Punchout/
Pins- Revenge From Mars/ Black Rose/ LW3
For Sale/ Trade: Digdug in Ireland Cab/83' Chexx Hockey/Battlezone/PC10 Bartop with 6 games
Check out http://www.flickr.com/kjarcade <--not updated
pefdude
  • Last login:June 15, 2012, 02:02:00 pm
« Reply #17 on: October 10, 2007, 01:17:09 pm »
aaron is the man! i've used chdman many times for just this reason. also contributed a couple images to the mame team for emulation.
Game-boi
  • Last login:March 24, 2008, 09:16:49 pm
« Reply #18 on: January 27, 2008, 09:41:04 pm »
So, seeing as this is my first cabinet, is it worthwhile to back-up the hard drive now? i.e., before a problem occurs...
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #19 on: January 28, 2008, 02:22:30 pm »
Watch out. "Harry" will turn you in to Midway, or whoever makes Gauntlet Legends.
NO MORE!!
Encryptor
  • Trade Count: (+34)
« Reply #20 on: January 28, 2008, 06:04:05 pm »
Spaz - Just an FYI.  I tried to download that Dolly program from the top link you provided but it asks for a username and password. I tried to email the admin with the email address at the bottom of the page and it was returned undeliverable.
Encryptor
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #21 on: January 29, 2008, 03:11:03 pm »
Tell me about it.
I was more than a little concerned when I got a call from Nintendo Of America the other day after tussling with Harry ... turns out they just had some stuff to send me, but it was a little freaky coming so close on the heels of that argument.
Working: Not Enough
Projects: Too Many
Progress: None
Spaz Monkey
« Reply #22 on: February 01, 2008, 09:52:31 pm »
Here's the file...
btp2k2
  • Last login:March 16, 2011, 01:02:36 pm
« Reply #23 on: February 01, 2008, 11:28:01 pm »
It's always a good idea to backup data...regardless of what it is and what is for....but in this case, since you are completely screwed if that data is gone....BACK IT UP!!!
Encryptor
« Reply #24 on: February 02, 2008, 06:55:49 am »
Spaz Monkey,
Thank you.  :)
Encryptor
Game-boi
« Reply #25 on: February 08, 2008, 09:28:52 pm »
So if I needed to backup/repair my machine by replacing the hard disk, anyone have any objections with an M-systems 1 GB flash disk? Do we think it will work? I found one in the $50.00 range, figure it may last a "life-time" this way. Anyone have specs on the original disk? I have the manuals and don't see nuthin' bout no hard disk...
rhuel
  • Last login:October 18, 2010, 07:36:08 am
    • 350XRiders.com
« Reply #26 on: February 21, 2008, 10:54:51 am »
I'm not at all familiar with "hard drive" Arcade games, but could one use dd in Linux to backup an arcade hard disk?
dd is used to make forensic backups of drives and doesn't care what FS or partitions are on the disk, it sees it as a device and copies bit by bit to the new drive.
Just a thought.
man page for dd
