Author Topic: Removing the "video emulation isn't 100% accurate" screen  (Read 12873 times)
sega_mad
  • Last login:July 09, 2015, 04:03:08 am
« on: September 18, 2007, 10:06:35 am »
Ok, so I'm compiling mame 1.02. I want to remove all the screens that say video, sound emulation not 100% accurate...then the next screen that has the data about the game and then says "press any key" ....plus the white box around the edge of the screen.
See attached picture....
I commented out the highlighted lines (and re-compiled) and it got rid of those messages but then it bought up other ones, removed those, and then it bought up more.....I think this would go on for ever!!
I'm sure I'm on the right track, but there must be an easier way, just one line I'm guessing..
Please help!!
ARTIFACT
Re: Removing the "video emulation isn't 100% accurate" screen
« Reply #1 on: September 18, 2007, 10:33:52 am »
its on byoac already
someone replied to the stickied hi-score thread hereand linked to that other info. go check it out.
ahofle
    • Arcade Ambience Project
« Reply #2 on: September 18, 2007, 12:07:07 pm »
You need to comment the code that displays the msgs, not the list of msg strings.  Search here as Artifact mentioned, this has been asked many times before.
sega_mad
« Reply #3 on: September 18, 2007, 05:28:31 pm »
Sorry, I've searched and searched...I can't find anything to help.
Could you advise the code I have to comment out please. Was I in the right folder MameSRC\src\ui_text.c
Cheers
MKChamp
  • Last login:February 07, 2024, 02:45:53 pm
  • Stil around.
« Reply #4 on: September 18, 2007, 05:45:41 pm »
You are talking about 'nag' screens. Go into mame.c starts at line 568.
   /* if we didn't find a settings file, show the disclaimer */
   if (settingsloaded || options.skip_disclaimer || ui_display_copyright(artwork_get_ui_bitmap()) == 0)
      /* show info about incorrect behaviour (wrong colors etc.) */
      if (options.skip_warnings || ui_display_game_warnings(artwork_get_ui_bitmap()) == 0)
         /* show info about the game */
         if (options.skip_gameinfo || ui_display_game_info(artwork_get_ui_bitmap()) == 0)
There are many ways to disable it...
Comment them out...be sure to comment out the opening and closing brackets.
or...
Change each if statement to  if (1)
sega_mad
« Reply #5 on: September 18, 2007, 08:23:03 pm »
MKChamp,
Thankyou very much.
Perfect, easy to understand instructions!!
Had to comment it out, changing to a (1) didn't work (maybe something I did wrong)!!
Can't thank you enough
Cheers
ARTIFACT
« Reply #6 on: September 19, 2007, 12:32:31 am »
ok but fyi
link to this info is posted on the last page of the hi-score thread thats sticky... where i got it.
take care
