Author Topic: ARCADEVGA JPAC2 TROUBLES??  (Read 1690 times)
killercomb0
  • Last login:September 25, 2007, 07:47:49 pm
« on: September 17, 2007, 11:45:39 pm »
hello all, well ive just recieved my arcadevga pci version2 and my jpac2 from andy at ultimarc.com.. well i installed both components into my deticated killer instinct2 arcade cabinet, at first i couldn't get a picture but then i only installed the arcade monitor plug by itself and it worked,, now what i dont understand is why my games run slower on my arcade monitor than on my actual computer monitor, on my computer monitor they run 100%, and on arcade monitor they fluctuate all the way down to 85%... also cant get a full screen on my arcade monitor, any help would be appriciated,, looked around but no luck!!!let mek now if you need pics..thanks all
killercomb0
Re: ARCADEVGA JPAC2 TROUBLES??
« Reply #1 on: September 18, 2007, 12:20:52 am »
btw my monitor is a neotec 25" nt-2500 model!!thanks all
ahofle
    • Arcade Ambience Project
« Reply #2 on: September 18, 2007, 01:09:15 am »
Sounds like you don't have the resolutions configured for the AVGA/arcade monitor + MAME yet?  Have you tried running a res tool or manually setting them according to the instructions on ultimarc's website?  What resolutions were you running 100% with on the PC monitor that are only 85% on the arcade monitor?
killercomb0
« Reply #3 on: September 18, 2007, 01:15:16 am »
well i gotta figure that out, im not really sure, im kinda not a computer person, but im going to look into it tonight more, i gotta figure out where to see the resolutions im running my games at? kinda having a hard time trying to get this monitor tuned in right!!!
ahofle
« Reply #4 on: September 18, 2007, 01:34:52 am »
You may want to try MAME32 if only to get the resolutions setup with its graphical user interface (as opposed to editing ini files or dealing with command line parameters).
Check out this page which has instructions for both MAME and MAME32:
http://ultimarc.com/avgainst.html
killercomb0
« Reply #5 on: September 19, 2007, 01:56:21 am »
WELL HELPS IF YOU READ THE INTERNET MANUELS.. thanks again ahofle for the heads up, everything works better now that i followed the instructions.. now all i need to learn is how to set the resolutions on each game, any links or tips for this guys...thanks again!!!
ahofle
« Reply #6 on: September 19, 2007, 02:21:06 pm »
There are tools around to set resolutions for all games.  Here is one of them (I've never used it though):
http://mamewah.mameworld.net/downloads.htm
Pay attention to the part about versions over 0.107 though.
EDIT: actually, check out http://ultimarc.com/avgainst.html again in more detail.  Toward the bottom, there is a "Auto-Resolution Utilties" section that has what you want.
« Last Edit: September 19, 2007, 03:19:50 pm by ahofle »
