Author Topic: Can Kinkos Print Full Sized Visio Files?  (Read 5477 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: May 01, 2003, 10:30:37 am »
I have the scale drawing of my arcade control panel plans in VISIO. Is Kinkos able to print me a full-sized version of this? Is it expensive to do this? I have already printed the file on my own printer across multiple pages, but Visio will not let me remove the printer's default margins, which causes a certain amount of whitespace on the sheets of paper (making it hard for me to line everthing up without breaking out the scissors).
Cue-Ball
  • Last login:August 28, 2006, 07:43:02 pm
  • Discs of Tron > *
    • Grant's Game Grid
Re:Can Kinkos Print Full Sized Visio Files?
« Reply #1 on: May 01, 2003, 06:58:23 pm »
Kinko's may or may not be able to print this in Visio format.  It all depends on your local Kinko's.  If you convert it to PDF format then you can get it printed for sure.  I had my overlay printed at Kinko's (converted from Visio to PDF first).  My CP is about 39"x16" and the printout only cost me $3 in B&W on 20lb bond paper.
