Author Topic: Help with Mala startup options  (Read 4366 times)
TexFlood
  • Last login:March 02, 2021, 07:37:29 pm
« on: September 16, 2007, 02:54:52 pm »
I've been looking around here for a few hours and can't seem to find the answer to what is probably a simple prob.
When I open Mala the first screen lists the following options:
Control
Genre
Manufacturer
Players
Year
How do I get rid of this filter menu?
If I use my Mala Tree configuration this menu will appear after I navigate down through my configured menus.  :banghead:
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
Re: Help with Mala startup options
« Reply #1 on: September 16, 2007, 11:58:18 pm »
I accidentally got myself in this situation in the past.  I couldn't get out of it either so I just restored a backup config.  Sorry man.  Have you emailed the author?
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #2 on: September 17, 2007, 02:07:22 am »
You have switched on the game list 'browse' mode. Switch it off and your lists will look normal again. You can find this toggle in the MaLa menu in the gamelist node. (Browse: On/Off)
TexFlood
« Reply #3 on: September 17, 2007, 08:10:28 am »
I've looked through the menus in Mala and I can't find the Browse checkbox that you are referring to.  I've attached screen shots where I thought they would be.  Can you give me a little more help with the location of that switch?
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #4 on: September 17, 2007, 09:05:55 am »
I don't think its in the options menus.  I know you can change it in the Main Menu:
Press 2 (or whatever key you have mapped to open the menu)
Select Game List
Change Browse to NO
swindus
« Reply #5 on: September 17, 2007, 09:17:55 am »
Or change the line Browse=1 in the file mala.ini to Browse=0
TexFlood
« Reply #6 on: September 17, 2007, 08:09:30 pm »
Awesome - that's the answer.  I found it both in the mala.ini file as well as by pressing 2 when I opened Mala.
Thanks SGT & Swindus!
loadman
  • Moderator
    • MaLa
« Reply #7 on: September 17, 2007, 08:17:02 pm »
I'll put that in the Wiki.
