Author Topic: Wei-Ya/Billabs monitor settings  (Read 1696 times)
arcadegamer
  • Last login:September 15, 2007, 06:23:09 pm
« on: September 15, 2007, 03:15:18 pm »
Hello,
Could someone provide a good set of monitior settings (i.e Horizontal 80, Trapezoid 50 , Pincushion 20, etc)
to use with a Wei-Ya/BILLABS BL27CB0P monitor ?  I've tried various combinations and have trouble getting both edges to be straight.  Unfortunately I didn't write what the defaults were when I first got it.  :banghead:
I'm using the Ultimarc ArcadeVGA video card and Mame32.
Any help would be greatly appreciated! :cheers:
Brendan
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
Re: Wei-Ya/Billabs monitor settings
« Reply #1 on: September 15, 2007, 03:50:12 pm »
Settings don't translate between monitors. If they did, all monitors could be set perfectly at the factory. And honestly, arcade monitors don't have the rock solid geomtery of a standard PC monitor. While you make get the geometry close to perfect, it'll never get totally perfect.
grantspain
« Reply #2 on: September 15, 2007, 03:55:35 pm »
don't you have a factory reset or a rescan facility on this monitor
Major Rock Hardy
  • Last login:April 29, 2013, 06:51:45 pm
  • xybots rocks!
« Reply #3 on: September 15, 2007, 08:54:32 pm »
have you tried factory recall in the menu yet?
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #4 on: September 17, 2007, 12:12:10 am »
Perfectly straight is not going to happen, typically you expand ther picture just beyond the screen, there is usually a fair amount of overscan in the games to allow for this.
My Websites
