Author Topic: CRT VERTICAL ISSUE  (Read 3239 times)
ViciousKid
  • Last login:February 21, 2018, 10:02:52 pm
CRT VERTICAL ISSUE
« on: September 15, 2007, 10:30:36 am »
Hi,
I currently have some arcade cabinets, two of the CRTs that came with it are having vertical screen issues, it looks like it is shrunk on the bottom of the screen and the picture goes off the screen on the top, so you can't see like your health etc. What can I do to fix this problem. I will get the model number soon and post it,  it is a Phillips monitor
« Last Edit: September 15, 2007, 10:32:07 am by ViciousKid »
Ken Layton
  • Guru
  • Technician
Re: CRT VERTICAL ISSUE
« Reply #1 on: September 15, 2007, 01:15:19 pm »
ViciousKid
« Reply #2 on: September 15, 2007, 09:14:10 pm »
here is the pic of the info for the monitor..
« Last Edit: September 15, 2007, 09:42:13 pm by ViciousKid »
SirPeale
  • Green Mountain Man
« Reply #3 on: September 15, 2007, 09:42:08 pm »
That's the tube.  Didn't you read the sticky BEFORE POSTING IN THIS FORUM, READ THIS FIRST!
SirPeale
« Reply #4 on: September 15, 2007, 09:54:31 pm »
Okay, you've got a WG K7500.
ViciousKid
« Reply #5 on: September 15, 2007, 10:02:09 pm »
i see thanks, any idea what could be the problem with the monitor?
SirPeale
« Reply #6 on: September 16, 2007, 10:29:16 am »
Post a picture of the screen.
ViciousKid
« Reply #7 on: September 16, 2007, 11:38:05 am »
this is the bad one..i just turned it on now..guess there is a black bar at the bottom now..
This is the Good one no black bar at the bottom or crunched up...but just noticed it still needs to be moved down as u can see the health bar is a little off the screen..
Fibonacci
  • Last login:January 28, 2009, 12:10:26 pm
« Reply #8 on: September 16, 2007, 10:11:37 pm »
They really just look like they need the position/size adjusted.
There should be a remote board with 4-6 pots labeled BRT, CON, V-POS, V-SIZE, H-POS, H-SIZE
ViciousKid
« Reply #9 on: September 17, 2007, 03:54:58 pm »
i can't find the remote board only checked one of the machines but pretty sure the other two don't have one either from when i opened them up, all there is the neck and other main board for the crt.
SirPeale
« Reply #10 on: September 17, 2007, 04:58:19 pm »
There *HAS* to be one.  Without it, the monitor will NOT function properly at all.
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #11 on: September 17, 2007, 05:00:42 pm »
Look for a control vertical Lin, Vline or similar.
By the way, these controls may be on the main board, not on an extended user remote board.
Let us know how you make out.
Rick Nieman
Rick@niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
SirPeale
« Reply #12 on: September 18, 2007, 08:12:39 am »
Not on a K7500.
And you can see the control cable in one of those pictures.  It's either that or the neckboard cable.
ViciousKid
« Reply #13 on: September 24, 2007, 04:35:03 pm »
i finally found the controls they were in the front of the game where you put the tokens in not in the back....still having a problem...i can adjust the height and stretch it out so the black bar does not show up on the bottom anymore but the screen becomes to stretched out that it goes off the screen both top and bottom and i tried adjusting the height position but it only moves down to a certain point...if it could move lower then the problem might be fixed....But i still noticed on the bottom of the screen still looks crunched up if it is not fully strecthed out..
sarge
  • Last login:April 27, 2015, 01:42:54 pm
« Reply #14 on: September 24, 2007, 11:35:32 pm »
You've got a vertical linearity issue.  Change all your c600 series electrolytic caps.
ViciousKid
« Reply #15 on: September 25, 2007, 12:08:47 pm »
where can i get a cap kit for this monitor?
