Author Topic: Extra button wiring?  (Read 2864 times)
Den
« on: March 15, 2002, 06:14:56 am »
Is the "Capcom CPS II Auxiliary Cable" found on http://www.mdgamesales.com/PCBCapcom.htm the same thing as the extra button wiring harness mentioned on http://members.aol.com/CMull11217/private/cps2faq.txt?
Den
Re: Extra button wiring?
« Reply #1 on: March 15, 2002, 08:34:24 am »
Assuming that it is (which I don't know), would I need 1 or 2?
Lilwolf
« Reply #2 on: March 15, 2002, 12:25:01 pm »
I don't know... what are you doing?
I don't have one and I don't need one.
You shouldn't need one (or have the ability to use it) if you are converting a capcom jamma cabinet to jpac
Den
« Reply #3 on: March 16, 2002, 09:20:57 am »
Hi Lilwolf, I have a Street Fighter 2 Turbo Championship Edition machine (old school Jamma) and am trying to convert it to Street Fighter Alpha 1.
SFA1 is a CPS2 system so it requires a different type of wiring harness for the extra buttons to work.  My question is if those auxiliary cables on mdgamesales are the ones that I need for the problem.
AlmtyBob
« Reply #4 on: March 16, 2002, 11:50:20 pm »
Yes that's the cable you'd need to wire the extra 6 buttons (3 per player) for Street Fighter type games.  However, $20 is robbery, look on ebay and use mdgames as a last resort.
Den
« Reply #5 on: March 20, 2002, 09:48:57 am »
Thank you AlmtyBob!
