Author Topic: How do you run Mame at 640x480?  (Read 4474 times)
Wienerdog
  • Last login:December 08, 2020, 06:28:51 am
  • If it's worth doing, it's worth overdoing
« on: April 30, 2003, 02:25:31 pm »
Is this controlled by mame itself?  When I am at 640x480, my games are all off the screen when I start Mame.
This opinion was created from 100% post consumed information.
Tiger-Heli
    • Tiger-Heli
Re:How do you run Mame at 640x480?
« Reply #1 on: April 30, 2003, 04:04:06 pm »
Command line MAME, in file mame.ini, change
resolution  auto
to
resolution  640x480
Wienerdog
« Reply #2 on: May 01, 2003, 06:38:58 pm »
resolution  640x480
I tried this last night.  When the game starts, it is scrambled.  Windows  resolution is 640x480 and looks fine, and mame is set to 640x480 but is scrambled when it starts.
BASSOFeeSH
  • Last login:May 29, 2009, 12:46:42 am
  • TD-2779
    • Trooper Armor
« Reply #3 on: May 02, 2003, 03:47:31 pm »
I always make sure that my refresh rate stays the same otherwise I see similar things.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: May 02, 2003, 03:57:50 pm »
I was thinking refresh rate also.  I run MAME at 800x600 and 85 Hz (PC monitor, obviously), and I think I have the refresh rate set to auto in MAME, but I also use Multires which I think ensures that the refresh rate doesn't change when a Windows program changes resolution.  Perhaps if I didn't have that, I would need to specify a refresh in MAME.
